May 22, 2008, 04:05:12 PM
| | |-+  73 to 72 conversion is it possible
Author Topic: 73 to 72 conversion is it possible  (Read 1181 times)
73 dart
« on: December 30, 2005, 09:01:28 AM »
I have a 73 dart in great shape ,i think i like the 72 front clip better ,what do i need to convert if possible and would i need to change anything on the rear .thanks
70 Dustpan
Sacramento CA.
Re: 73 to 72 conversion is it possible
« Reply #1 on: December 30, 2005, 10:28:31 AM »
It's been done before. You need to swap pretty much the whole nose of the car. If you can find a complete donor car then if not all that hard. Trying to find all the parts part by part could be a pain.
Hey, I'm a God again!
abodyjoe
South Jersey...
abodyjoe
« Reply #2 on: December 30, 2005, 11:10:10 AM »
yea basically you need the entire front clip...  best bet is like already stated find a donor car...
70 Dustpan
Sacramento CA.
« Reply #3 on: December 30, 2005, 02:47:52 PM »
Also a 4 door car will work as a donor car. The front nose is the same as a 2 door.
Lobukdstr
« Reply #4 on: December 31, 2005, 08:30:22 PM »
Mine is a '74 in which I now have a '70, '71, and '72 front end on it. You can retain your '73 fenders so your marker lights will match the rear ones, but will have to add support tabs for the latch header panel under the hood...
Before:
After:
Hope that works
How do you know it won't work?? Have you tried it yet??
72Dart_400
Rome, PA
RyanRM340
« Reply #5 on: January 03, 2006, 03:36:12 PM »
It's not too hard to do, like said just change the front.  Easiest way is to find a donor car.
Midnight Special
GO HARD or GO HOME
midnightsplracin
« Reply #6 on: January 04, 2006, 01:56:04 AM »
73 Dart....it can be done.  One thing we often forget that Dart fenders are more radiused for a larfer front tire as where Duster fenders werent.  You'll not be able to use a larger tire with Duster fenders w/o possibly cutting raduises larger.  Dart fenders are a better choice in my book.  My son derrick has a 73 Sport and the same front tire I have and didnt have to cut a darn thing like I did. [B] JUST FYI[B/]
Wichita Kansas Area
NHRA/SFI Tech Inspector
NHRA Division V
jamesdart
« Reply #7 on: January 04, 2006, 05:11:21 PM »
on a dart, the front of pre 73 fenders are different, they have the fender extension, the 73 doesnt, they are similar to 67-69. a duster you could get away without changing the fenders.
