Topic: which primer to use ?? (Read 475 times)
dusterdarryl
im deep up to elbows in this vinil roof repare on my Aust Chrysler by Chrysler, & as you can see im very close to layin a coat of primer on the roof. Im going to paint the roof the same colour as the car & I see in the auto shop has various different primers...like ech primer & arcrilic etc,which shoud i use? & what about spray putty for those anoying little pit holes, is it any good ?
Teeto
I would use a urethane high build primer filler. I use ncp/270 or ncp 271 from PPG. Very high build and very corrosion resistant. If you decide to use it let me know and I can give you more info on the product.
jamesdart
i like epoxy primer of bare metal. do the body work and high build primer over it.
rjsjea
R-M ep789.....epoxy undercoat....top of the line in body shops. After epoxy use your filler..
dusterdarryl
R-M ep789.....epoxy undercoat....top of the line in body shops. After epoxy use your filler..  i thortmyoud use the filler before the primer (undercoat) ?
DartKnight
I assume he meant filler primer; it's the same as high-build...I love that stuff.
Jason
I am not a painter, but my buddy uses K200. I think it may be the same as filler primer.
Cary Snyder 5.7L Hemi Cuda
vancamp
VanCamps Paintless Dent Repair
for a filler primer thats not to expensive you might try Nason 2k high build, you can get it in grey or buff (yellow) its a cheaper line of dupont.
abodyjoe
first spray epoxy primer on there.. man that stuff is good..
then you do your body work. make sure you re prime anywhere you break through wile sanding..
then you use your high build urathane primer...
mopowers
What is self-etching primer? And is it similar to epoxy primer?
abodyjoe
no they are not the same...
rjsjea
To clarify....use epoxy primer on bare metal, then body filler (bondo or similar), then a high build primer..........
dustertogo
RM ep 789 on bare metal, then bodyfiller then primer over the filler. If the filler work is kinda rough, spray filler works nice for small imperfections but still has to be primed.
sweatybetty
now that i have a brighter future, im going to start brushing my teeth
dusterdarryl
geez thats what Iv been lookin for, thanx for that, iv takin it back to the bone & covered it in rust converter then sanded that back then iv sprayed it with an exopy eich primer, [attachment deleted by admin]
