December 02, 2008, 06:54:11 AM
| | |-+  which primer to use ??
Author Topic: which primer to use ??  (Read 538 times)
dusterdarryl
« on: March 16, 2006, 12:17:36 AM »
im deep up to elbows in this vinil roof repare on my Aust Chrysler by Chrysler, & as you can see im very close to layin a coat of primer on the roof. Im going to paint the roof the same colour as the car & I see in the auto shop has  various different primers...like ech primer & arcrilic etc,which shoud i use? & what about spray putty for those anoying little pit holes, is it any good ?
Teeto
Re: which primer to use ??
« Reply #1 on: March 16, 2006, 11:24:00 AM »
I would use a urethane high build primer filler. I use ncp/270 or ncp 271 from PPG. Very high build and very corrosion resistant. If you decide to use it let me know and I can give you more info on the product.
« Reply #2 on: March 16, 2006, 04:04:13 PM »
i like epoxy primer of bare metal. do the body work and high build primer over it.
« Reply #3 on: March 16, 2006, 11:41:37 PM »
R-M ep789.....epoxy undercoat....top of the line in body shops. After epoxy use your filler.. Smiley
dusterdarryl
« Reply #4 on: March 17, 2006, 03:44:45 AM »
  i  thortmyoud use the filler before the primer (undercoat) ?
DartKnight
« Reply #5 on: March 17, 2006, 04:16:18 AM »
I assume he meant filler primer; it's the same as high-build...I love that stuff.  Grin
Jason
« Reply #6 on: March 17, 2006, 09:16:38 AM »
I am not a painter, but my buddy uses K200. I think it may be the same as filler primer.
vancamp
VanCamps Paintless Dent Repair
« Reply #7 on: March 17, 2006, 09:29:23 AM »
for a filler primer thats not to expensive you might try Nason 2k high build, you can get it in grey or buff (yellow) its a cheaper line of dupont.
« Reply #8 on: March 17, 2006, 10:01:44 AM »
first spray epoxy primer on there..  man that stuff is good..
then you do your body work. make sure you re prime anywhere you break through wile sanding..
then you use your high build urathane primer...
« Reply #9 on: March 17, 2006, 04:56:57 PM »
What is self-etching primer?  And is it similar to epoxy primer?
« Reply #10 on: March 17, 2006, 05:33:09 PM »
  no they are not the same...
« Reply #11 on: March 17, 2006, 06:41:10 PM »
To clarify....use epoxy primer on bare metal, then body filler (bondo or similar), then a high build primer.......... Cheesy
dustertogo
« Reply #12 on: March 17, 2006, 09:03:36 PM »
 RM ep 789 on bare metal, then bodyfiller then primer over the filler. If  the filler work is kinda rough, spray filler works nice for small imperfections but still has to be primed.
sweatybetty
« Reply #13 on: March 19, 2006, 12:52:19 AM »
http://www.autobody101.com/forums/
check out this site. very informative
dusterdarryl
« Reply #14 on: March 19, 2006, 01:37:02 AM »
geez thats what Iv been lookin for, thanx for that, iv takin it back to the bone & covered it in rust converter then sanded that back then iv sprayed it with an exopy eich primer,
