December 03, 2008, 12:15:06 AM
| | |-+  Dented tail panel, get a puller, or take the panel off?
Author Topic: Dented tail panel, get a puller, or take the panel off?  (Read 199 times)
Lars
ATX
« on: March 16, 2006, 08:50:43 PM »
I'm going to start working on my 74 Duster soon, I'm gonna swap in one of my spare SB engines to get it on the road. I'm gonna to do the bodywork last, but there are a couple things on the body I have to fix before I can get it on the road. One of them being the tail panel is dented in pretty good. I have a set of body hammers and dollies, but the trunk bracing is covering enough of the panel that I can't really get to it like I need too. So as I see it I have two options, get a spotweld cutter, remove the panel and straighten it on the bench, or get one of those stud welders that weld the pin onto the panel so that you can pull it out with a slide hammer. The downside to this is the stud welder is much more expensive then the spotweld cutter, the upshot however is that I can use the stud welder to pull some of the dents in my quarters later on so that I may not need full skins when I start on the bodywork. What do you guys think? I'm leaning towards the dent puller, but it really costs more then I want to spend (trying to do this car super cheap).
Re: Dented tail panel, get a puller, or take the panel off?
« Reply #1 on: March 16, 2006, 10:34:10 PM »
Harbor freight has some cheap stud welders.  I haven't tried one or talked to anyone who has but I was considering one.  Anyone out there ever use one?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3223
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=8878
Lars
ATX
« Reply #2 on: March 16, 2006, 11:13:24 PM »
Hadn't seen those before. May have to check them out.
« Reply #3 on: March 16, 2006, 11:38:51 PM »
Stud-pullers work great, but in tools, specifically body work tools......you get what you pay for....a good quality puller will last forever, even in afull time  Cheesy body shop
4speeddemon
« Reply #4 on: March 16, 2006, 11:57:24 PM »
i got one from harbor frieght..... ive only used it a few times ( on my tail panel..and a few other places) but it works fine... it was the cheaper one of the two
4speeddemon
IF YOU WANT BLOOD, YOU'VE GOT IT
GTSDave
« Reply #5 on: March 17, 2006, 12:07:42 AM »
I bought the cheap harbor freight one and have been using it for a couple of years. I buy the replacement studs at my local paint supplier.  The only gripe I had about mine is the cheap slide hammer it comes with.  Get a better slide hammer to pull the studs with and you will like it.
I must have use a hundred studs on my GTS once I figured out how to use it.  I pulled a scratch / dent across the rear of my deck lid that was almost 2 feet long!  Think like a keyed paint job.  Just the key pushed the metal in almost a half inch.  I would have had to trash this deck lid if not for the stud puller.  One of the best buys I made while doing the body work on my GTS.  I waited till it went on sale and picked it up for $80 something dollars.
-Dave
« Reply #6 on: March 17, 2006, 12:42:06 AM »
Good feedback.  I got a 20% off the purchase of one item coupon that I have to use before Sunday.  Maybe I'll go get one.
Lars
ATX
« Reply #7 on: March 17, 2006, 12:48:47 AM »
Yeah this is good news for me too! I may end up getting one, maybe my 1/4's won't look so hammered after all.
« Reply #8 on: March 17, 2006, 01:16:50 AM »
rjsjea, I hear what you say and it's true for all tools.  But.... I love doing body work like I love getting the flu so I would use a tool like that only once in a while for my own cars. (or the first buddy who asked to borrow it)  I use harbor freight oddball tools for things I do ocasionally.
