July 24, 2008, 07:04:34 AM
| | |-+  New to All -Tire QuestionsAnd Wheel and Tire Combo's
Author Topic: New to All -Tire QuestionsAnd Wheel and Tire Combo's  (Read 22621 times)
DustBuster
Re: New to All -Tire QuestionsAnd Wheel and Tire Combo's
« Reply #30 on: April 20, 2006, 01:24:55 PM »
do you guys know if a 225/70/15 will rub up front on any turning?
on a 71 Demon?!
I doubt it. I had my tire guy mount a 215/70-15 on the front and it hit the bottom front edge of the wheelwell. I had to go to a 205/65-15 0n the front and that cleared by about 1/2" ! (This was on a ARE Outlaw I 15x7" rim w/ 3-3/4" backspacing
demon340v
« Reply #31 on: April 21, 2006, 12:07:34 PM »
on a 71 Demon?!
yeah i stopped in at pepboys yesterday the guy said find a 15" rim and i'll be more then happy to  mount a few diffrent tires that way we know what you can run for sure. he just said stay with the 60 series tire because of teh 1" larger rim will give me a bit more on height  to  begin with.  SO i'm trying to track down a rim now and i'll let you guys know!
BlowDart
« Reply #32 on: May 22, 2006, 11:00:39 PM »
I just purchased a 69 Dart that has an 8 3/4 narrowed 2 in./side,3" inboard kit,15x10 steel wheels w/dog dishes with M/T's 29x12.5x15 sportsmans with stock wheeltubs I am not sure on the backspacing I have yet to bring the car home.There is lots of clearance between the leafs and the wheelwell when I first seen the car I thought for sure it was tubbed I am very happy with the tire width and not having to cut the car up.I would guess this would be the biggest tire you can fit with stock tubs.
nightrider
Duster Buster
« Reply #33 on: May 26, 2006, 04:13:55 PM »
Just got some 15x7's with 4" backspacing.... Stock Duster no suspension mods, Will a 255 70 15 fit the car? 60s will but i want a taller tire...
« Reply #34 on: May 26, 2006, 04:29:17 PM »
do they even make 255/70/15s?  I wonder what the dimensions would be.
DustBuster
« Reply #35 on: June 01, 2006, 12:54:42 PM »
rim size 6.5-9"
section width 10.1"
Diameter 28.9"
These are BFG's
DART340
« Reply #36 on: July 23, 2006, 08:35:56 AM »
   I HAVE A 72 SWINGER, THE AXLE HAS BEEN MOVED BACK 1.5"(EASY TO DO) AND I RUN 275/70/15 ON STOCK 15X7 RALLY
AdamR
« Reply #37 on: July 26, 2006, 07:33:18 PM »
I've run a ton of differant tires on my Barracuda.
Fronts, all on a 15X5.5" rim
175-70
205-70
215-60
215-75
Rear on a 15X8.5" with a 4-7/8" backspacing
235-70
255-60
After moving the springs
275-50
325-50
www.forabodiesonly.com
Forums and classifieds
« Reply #38 on: August 25, 2006, 05:56:58 PM »
'67 Dart. Wheel wells and springs relocated per the tech pages. Inside wheel well massaged and lip trimmed per my photo gallery.
MT 325 / 50 / 15's on 15" x 10" wheels with 7.25" backspacing on a standard width A body rear end will give you 3/4" side clearance. I missed the backspacing by 1/4" therfore I have a strong 1/2" on the outside and a weak 1" on the inside. This is also with Ford Explorer disk brakes.
Caledonia, ON Canada
« Reply #39 on: August 25, 2006, 06:56:11 PM »
That looks awesome Tom Cool
« Reply #40 on: August 25, 2006, 07:01:52 PM »
Thanks, I through some pics in the off topic area. this site is all about the pics. drinks
BIG DOG
« Reply #41 on: September 04, 2006, 03:36:04 PM »
Tom I want to keep my axle stock also and have been wondering about this .Are you saying that you ordered yours 7" and they should have been 7.25" or that you ordered 7.25" and 7.5" would have given you 3/4" on each side.
Blair
« Reply #42 on: September 09, 2006, 12:50:20 AM »
Blair
I ordered mine 7.5 inch backspace and I should have ordered 7.25. It will still be O.K.
Also, My backspace is for a big late Ford disk brake set up with 2.5" axle flange spacing. A drum will be a little different.
The 13.5" wide M/T actually measures no more than 13.3" with weight on it.
« Reply #43 on: September 10, 2006, 07:20:35 AM »
I'm looking at those new American Racing Vectors for when I finally get my project on the go
front:
15 x 7 with 4 inch backspacing and +6mm offset
rear:
15x 8.5 with 5 inch backspacing and +6mm offset
will these fit? biggest tire I can run?
I don't suffer from road rage, I enjoy every minute of it.
My vehicles:
-1984 Dodge Ramcharger 318 auto 4x4 atc stock beast
-1968 Dodge Dart GT 6cyl auto buckets console work in progress
-1966 Bridgestone 90 Deluxe
-1946 Fargo 3/4 ton
Miami340Duster
« Reply #44 on: September 28, 2006, 08:31:46 AM »
go to www.tirerack.com and they have a chart that gives you the measurement of tire/wheel combo's that fit each particular car and also keep in mind that if your car is not shown useyour imagination....ie...66 dart may not be illustrated but a 74 dart just might be....I dont know that they are too much different for a wheel tire combo....Also, I believe that they also have a chart that says like if you mount a 215-60-15 tire on a 15x8 wheel with this much offset your tire wil be ___ inches tall...pretty good application./.....
« Reply #45 on: October 22, 2006, 02:31:02 PM »
245/3518  8.5 rim slight trim on outside lip because its low 275/3518 on 8.5 rim back because its low i have a finger clearence on either side with sligtly massaged inner wells ladder bars no tubing
67 dartgts
Go fast or go Home
« Reply #46 on: November 12, 2006, 12:33:44 AM »
 Heres mine 67 Dart ..mini tubbed ,,,springs relocated..stretched wheel opening...opening lip removed replaced with steel rod..Wheels Centerline 15 inch / 10 inch wide / 5 inch back space...tires Hoosier 29x15x12...room to go bigger yet .
 Maynard
496dart
« Reply #47 on: November 29, 2006, 03:19:36 AM »
I finally got my rear wheels on the 70 dart today . They fit-------barely.
weld pro stars 15 x 8 w/ 4.5" backspace
MT --ET street  28x 11.5x 15 tires
stock location leafs
outer quarter lip is rolled in.
wheels tubs moved in 2 inches .
I have 1/2" clearance at the tire/ leafs  and about 1/2"  at the tire / quarter lip .
these would NOT have fit without rolling in that quarter lip.
kzinge1
'70 Dart 383
« Reply #48 on: November 29, 2006, 03:55:17 PM »
Anybody use 315/60-15's on a Dart with minitubs and relocated springs? I know they will fit in a Duster but am unsure if they will fit in my Dart.
15x10" rim with 7 1/2 backspacing
« Reply #49 on: December 07, 2006, 11:51:52 PM »
TOM YOUR CAR LOOKS GREAT,HOPE YOUR GOOD ON THOSE MEASUREMENTS BECAUSE IM DOING THE SAME SET UP AND IM GOING OFF YOUR SIZES FOR MY BUILD ,ILL LET YOU KNOW HOW IT GOES duster
To state the obvious, get the rear under the car with the brakes before ordering the wheels. 1/4" off on the backspacing is a big deal. After you trinm the lip and go for the body side of the wheel well seam removal, run a /045" grinder along the seam and it almost lays back by itself.
« Reply #50 on: December 27, 2006, 08:44:25 PM »
yes this is what i have on the back of my 69 for street duty. if i remember correctly, they are 29x10 on a 7" rim. just barely fit for hirght.
duster-dan
« Reply #51 on: December 29, 2006, 03:09:21 PM »
Hagenbeasley
      WELCOME A BOARD
  SO I MAY NEED A LITTLE HELP NOW AND THEN. ANYWAYS I HAVE A COUPLE OF MOPARS  AND I THOUGHT I WOULD SHARE MY TIRE AND WHEEL INFO WITH YOU ,FOR ANYONE THAT IS HAVING TROUBLE WITH THE AGE OLD QUESTION  OF HOW WIDE OF TIRE CAN I RUN ON MY CAR. THIS CAR HAPPENS TO BE A , 72 SCAMP W / A 318. ANYWAYS ON THIS CAR I HAVE TORQ - THRUST II WHEELS I WAS ABLE TO RUN A
16 X 8 REAR WHEEL WITH 4.88 B.S. AND +10 MM OFFSET WITH 245/50/16 ON THE REAR WITHOUT ANY MODS TO THE REAR AT ALL . THE TIRE DIA. IS 25.9 ...
WITH A SEC WIDTH OF 10.3,WHEN MOUNTED UP AND SITTING ON THE GROUND.   I TRIED ABOUT SIX DIFFERNT TIRE / WHEEL COMBOS W/DIFFERENT BACK SPACING AND THIS IS THE WIDEST YOU CAN FIT WITH THIS BACK SPACING ,AND NO I DID NOT HAVE TO ROLL OR CUT THE OUTSIDE LIP AND THEY DO NOT RUB ,EVEN IN A CORNER.
NOW UP FRONT WELL YOU HAVE ALOT OF CHOICES ,I RUN A TORQ - THRUST II  15 X 6 WITH 3.38 B.S. AND - 2 MM OFFSET WITH 195/55/15 ON THE FRONT. HOPE THIS HELPS SOMEONE OUT . I DONT SEE MANY SCAMPS ON THIS SITE ,AM I LOKING IN THE WRONG PLACE ? OR IS THERE MORE SCAMP OWNERS OUT THERE?
bbd sign          any pics of your car on the ground with your wheels on it?
Rynos69
« Reply #52 on: January 10, 2007, 11:21:00 AM »
I have weld wheel rims and Hoosier Quik Time Pro 26x9.50 15LT out back and Mickey T's
sportsman 26x7.50 15LT on the front. Thats the biggest I could fit.
mj440
« Reply #53 on: January 22, 2007, 05:22:45 PM »
295/50/15 on my 74 challenger fit with minor adjustments to the inner fenderwell lips.
I miss my challenger
« Reply #54 on: February 06, 2007, 07:32:51 PM »
I have Weld Draglites 15x6 w/3.5 bs on front with 215/60r15 and 15x8 w/4.5bs or rears with 265/50r15. Bareley fit on a 68 dart, but I know you can go 275/60 on the Dusters & Demons.
« Reply #55 on: February 12, 2007, 08:54:45 PM »
New topic for me......just curious.......why are some pictures deleted by admin? I just want to know what the restrictions are so I don't post any "no no's" Is it because these pics are copy writed?
Jim
« Reply #56 on: February 15, 2007, 05:37:27 PM »
11.75 disks with b body calipers
front rims- i have 15x7 standard Chrysler steel wheels off a  80s new yorker- 4.25 backspacing, no rubbing at all on suspension
front tires- i have a Yokohama 235/60r15 and they are an amazing tires and grip ALOT better than bfg traction t/as plus do very well in the rain as well- they wont fit on the front of a duster without modification because they hit the backside of the wheelwell but they will fit a dart easily because the wheelwell gos down at an angle not like the duster that curve around, a dart will fit 235s, 245s for sure and maybe even a 255- this is in the front
rears yet to come
340dart
« Reply #57 on: February 20, 2007, 12:06:37 PM »
heres what i did i have a 69 dart with stock width 8 3/4.  i have 275/60r/15 nitto drag radials on custom made 15x8 cragar ss with 5" backspacing.  the car has custom made brackets for the leafsprings to move them 3/4" over against the frame. the wheel well lip is trimmed and inside of the quarter theres a bump wich i carfully pushed out with a jack without recking the paint(crushed the bump just enough). with that tire and 5" backspacing is the only way i could se it fitting i have barely 1/2" maybe on both side  maybe a 1/4.  the car did rub untill i added a few leaves to my jcwhitney springs. it sits great now.  hope this helps and remember dart and barracudas and dusters, ETC are different when it comes to this.  ill try to send pics.
ucdcrush
« Reply #58 on: March 03, 2007, 03:11:22 PM »
Front: '67 Dart with Diplomat disc brake setup
Weld Prostar 15x5", 3.5" BS, tire: BF Goodrich Traction TA 205/70/15 (26.3" tall)
blown71duster
« Reply #59 on: March 04, 2007, 03:18:02 PM »
  PIc of 315-60R15 MT drag radials on my duster. I would say this is probably about the biggest you can run in the MT line with a mini-tub. Had to section the front of the quarter and inside of the rocker
1971 Duster 440  Single turbo
Pages: 1 [2] 3 4 Go Up Print
