Topic: Should i lower my car it sits high? (Read 702 times)
cold85
My car seems to sit high i would like to lower it do all i need to do is turn the torsion bars and if so where would i stop at? [img][/img]
Online
That looks high. Any ride height adjustment requires realignment. I usually try to put about 1" between the LCA bumper and frame.
Rocky Ak
are those fenderwell headers?...makes lowering the front a bit more difficult.
SIKPUP
just take it off the trailer, that sould lower it a good foot and 1/2  Thats what I was gonna say !!! SIKPUP
 Spring City, Pa.
cold85
Everybody is so funny. But no help
sr71mopar
I kinda like the look of a high sitting hot rod.
you might try the old optical dillusion trick--- put larger tires on it. ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif)
DartKnight
I just went in 1/4 turn increments on the torsion bolt; like Rocky said, I'd take it easy with those headers.
Jason
imfamousjim
thats what my car comes back like from midas... they've done two of our cars and theyve both sat high as hell. im just gonna go get it aligned at a diff shop.
sr71mopar
My car is not done yet, but I also have pro parts headers. I have a funny feeling my car wont be too low.
bentwheel43
I have hookers but I have to set mine low,because if you put it higher with the torson bars it wants to float. They rubb bad but going strate they have about 4"  I race it only!! BE SAFE, MAX [attachment deleted by admin]
Ciscodog
Lowering the front is going to make the back look WAY higher. If you were to lower the back with some lowering blocks the front will settle down a bit. Then all you'll need is a turn or two on the bars. It will help your weight transfer too. That forward rake never helps...
