July 24, 2008, 12:50:33 AM
| | |-+  tie rods & drag link
Author Topic: tie rods & drag link  (Read 493 times)
440turner
« on: March 21, 2006, 08:26:27 PM »
  I am about to swap over my front suspension pieces from my /6 k member and suspension in my 67' Barracuda. I have purchased a front suspension from a 73-76 A body, but I am wondering what tie rod ends and adjusting sleeves I need? Do I buy the pcs. according to the car( 1967 Barracuda) or should I buy rod ends and adjusting sleeves for a 73-76 A body? Is my 67 drag link going to work I believe it is a /6 piece, and im installing my 68' 440? Why do I thimk my oil pan is also not going to clear?
70 Dustpan
Sacramento CA.
Re: tie rods & drag link
« Reply #1 on: March 21, 2006, 11:02:29 PM »
The tie rod ends and sleeve are the same for 67 to 76. If you have a 73 and up idler are and pitman arm then they won't fit the 67 drag link.  Is your K frame still the 67 one?
Hey, I'm a God again!
440turner
« Reply #2 on: March 22, 2006, 05:39:24 AM »
I am installing the 73-76 k member, so I will have to purchase a new idler and pitman arm, along with a v8 drag link. Will I be required to buy an A body big block oil pan or will an 8 quart moroso pan fit?  Im not afraid of clearencing the kmember as long as its not to drastic. I have a standard B body factory oil pan, will this pan fit?
70 Dustpan
Sacramento CA.
« Reply #3 on: March 22, 2006, 06:22:23 AM »
Most likely you will need a C body pan that has the notch for the idler arm to clear or a after-market pan made to fit an A body. With that K frame just get all the suspension parts for a 73-up A body.
« Reply #4 on: March 22, 2006, 12:05:28 PM »
You can use the 67 link, but you will need a 68-72 idler arm. The pitman arm remains the same. If you go to the 73-76 link, you will also need the 73-76 steering gear (you may be able to find a small sector pitman arm for the later link which would enable you to run the early gear).
DartKnight
« Reply #5 on: March 22, 2006, 08:40:40 PM »
I'm going to be using the mid-seventies C-body stock tie rods and adjusters; they are a lot stronger from what I hear...
Jason
70 Dustpan
Sacramento CA.
« Reply #6 on: March 25, 2006, 05:29:17 AM »
I grabbed a set of those out at the yard, but the sleeves were too long. They are 8 5/8's long and with the ends all the way in I still couldn't get the wheels straight and even. So I had some made up out of alum. hex stock at 7 1/4" long and now with the tires straight and there is about 1/4" of thread still showing on all the ends.
DartKnight
« Reply #7 on: March 25, 2006, 07:32:02 AM »
Thanks for the tip; I'll make a note of that... Wink
Jason
