December 03, 2008, 12:22:28 AM
| |-+  Early A-bodies
| | |-+  Pushbutton trans shifter mech removal
Author Topic: Pushbutton trans shifter mech removal  (Read 595 times)
bbscamp
Ehm.....B5 Blue am I?
« on: March 21, 2006, 10:16:39 PM »
how do you properly remove the wiper and headlight switches....and the shifter mechanism for a pushbutton trans?    I don't feel like breaking anything taking it apart!
VDART
Re: Pushbutton trans shifter mech removal
« Reply #1 on: March 22, 2006, 01:06:22 AM »
#1get a manual-- has pics-- #2 allow time enough so you don't break anything
headlight switch--- shaft pulls out of housing-- must push in release button on the body of the switch-- may have to wiggle-- contort body to do this-- once shaft/knob assy-- out take off locknut-- assy should now come out
wiper switch -- much easier than headlight -- loosen locking nut that holds knob onto shaft-- once knob is off-- loosen lock nut holding switch to dash
p/button assy--loosen dash  -gauge cluster-- take pics --if available-- remove p/brake cable assy--& springs--- check out assy-- you will see how the cables are attached---- shifter cable also has mounting collar-- remove it from the shifter assembly & then remove  the assy-- cables should sta in the car--
Take your time-- come to Ks & i can show you -- Good Luck
