Topic: MADDOGS dont fit (Read 754 times)
70 Dustpan
I really don't think the later stuff will help you much because even though it comes from the top the center link sits in about the same space.
Hey, I'm a God again!
4406
Mine rub a little but WOW. Id be contacting the manufacturer. You could have the header notched, Ive seen it done. That's not to say if someone has a solution that is a bolt on pass it along.
Crazy68Dart
Does Maddog state that they will fit your combo? Headers in BB A-bodies are not for the faint of heart...
qkcuda
How high is the crank cetreline above the top of the K member. I had all kinds of clearance issues on my Hedmans until I raised the motor. You may be sitting too low. I know that won't solve the interference you have now, but maybe that and a change to the late model linkage will.
dusterdarryl
Andy, there is next to no room for small blocks to have headers in there let alone RB biggies, headers are a pain at the best of times as im sure you know, iv got to admit though for mine i went to fender exits, even though the rub the tyre on them a wee bit its worth it to get away from the greith that other headers bring. hows the cuda?
 with qkcuda. start raising the motor until youi get what you need.  crazy68dart summed it up best. just go out there and take charge, you get it to fit.
cool ok then. head to the local wrecking yard. starting sometime in the early 70's the steering parts were flipped over so that your problem treaded part will be on the bottom and GRAB all the related parts. go to the tech pages under steering and you'll see the changes.
Crazy68Dart
...or send them back, and get a set of TTIs... you running stock style heads?
dodgee
hi guys running eddy heads and wrecking yards in new zealand dont carry mopar stuff have to source in the usa, tried to fit left side,torsion bar wont go back in as the header is in the way and the collector is up above the subframe somewhat.
hmmm, big problem you got there. the more your try the more problems you encounter. it's looking like sending them back may be the right thing to do. the first motor i put in the  was a 440 with stock type heads. i used what at that time was cppa headers, which is i believe todays tti's and it was a real fun way to spend several days of coarse a few beers did ease the pain a bit.
Crazy68Dart
hmmm, big problem you got there. the more your try the more problems you encounter. it's looking like sending them back may be the right thing to do. the first motor i put in the  was a 440 with stock type heads. i used what at that time was cppa headers, which is i believe todays tti's and it was a real fun way to spend several days of coarse a few beers did ease the pain a bit. Yeah, I can image. I think the TTIs should fit better than the CPPAs did. You have some serious clearance issues. You are either going to have to start cutting or get something different. Are those 2" primaries? I would call TTI and describe your situation. As long as your engine is in the stock location, running stock type exhaust ports (which you are with the Eddy's) I would think TTI would be able to help you out.
