November 21, 2008, 11:49:08 PM
| | |-+  Tire too close?
Author Topic: Tire too close?  (Read 1823 times)
Halfaed
To move rapidly
Tire too close?
« on: December 31, 2005, 12:06:06 AM »
My tire is about a 1/2" away from the frame on my car, is this too close? I have new bushings in the leafs. Just wanted your opinion.
Thanks guys.
Sacramento CA.
Re: Tire too close?
« Reply #1 on: December 31, 2005, 12:17:27 AM »
That's about as close as you want to go, also make sure that there is nothing that can cut the tire bring that close.
Re: Tire too close?
« Reply #2 on: December 31, 2005, 12:48:05 AM »
It shouldn't be a problem. There will be some body sway in corners, though.
Re: Tire too close?
« Reply #3 on: December 31, 2005, 10:24:08 AM »
Keep in mind how tall is the side wall of your tire's. The less side wall the less roll in the tire. The down side is ride quaility. Good luck with your project.
383man
Re: Tire too close?
« Reply #4 on: January 01, 2006, 03:06:55 AM »
These are 28 x 9 tires we squeeze in the boys Dart's stock wheelwell.? The M/T slicks we use at the track are the same size and they have about 1/4 to 1/2" at most on the inside and outside.? And they are about 1/2" from the front of the rear wheelwell.? Everything seems to wokk fine but the slicks rub at times a bit in the traps.? Ron
Dartsport
Re: Tire too close?
« Reply #5 on: January 01, 2006, 12:45:17 PM »
I have about 1/2" clearence on my car, between tire and frame. It is enough, they don't rub!! 4 speed
Halfaed
To move rapidly
Re: Tire too close?
« Reply #6 on: January 03, 2006, 05:36:41 PM »
Thanks guys! bbd sign
