November 21, 2008, 11:39:40 PM
| | |-+  Swiching to '73-'76 drag link.....can I still use my '67 lower control arms???
Author Topic: Swiching to '73-'76 drag link.....can I still use my '67 lower control arms???  (Read 253 times)
Dartgtx
« on: March 25, 2006, 12:28:01 PM »
Hello all,
I know many have done this swap.  Here is my dilema.  I now have a '73 K frame modified to fit my 451 and I have the centerlink, manual steering gear, pitman and idler arms.
The '73 joints all point toward the ground.  My '67 ball joints point toward the hood.  This would create a monstrous 'bump steer" issue. \/][
SOOOO,  what is the fix???
Thanks in advance,
thank you
70 Dustpan
Sacramento CA.
Re: Swiching to '73-'76 drag link.....can I still use my '67 lower control arms???
« Reply #1 on: March 25, 2006, 01:02:31 PM »
What spindles are you using, the 67s or 73s?
Hey, I'm a God again!
Dartgtx
« Reply #2 on: March 25, 2006, 01:45:47 PM »
'67 spindles..........original 9" drum brake car, now wilwood kit for '67 drum spindles.
70 Dustpan
Sacramento CA.
« Reply #3 on: March 25, 2006, 02:27:04 PM »
I know that the outer tie rod ends on the 73-up mount to the end of the ball joint from the under side and point up and I 99% sure that so do the 72 and older ones too.
dusterdarryl
« Reply #4 on: March 25, 2006, 05:43:02 PM »
can you show us a pic ?  iv never heard of A body or any B, C bodys like that duster
70 Dustpan
Sacramento CA.
« Reply #5 on: March 25, 2006, 05:49:07 PM »
Who are you asking that of?
« Reply #6 on: March 26, 2006, 12:28:23 AM »
I don't believe there is a difference in the lower ball joint besides the spacing of the spindle holes. The tie rods all angle downward to the outside.
