October 07, 2008, 11:38:58 AM
| | |-+  73 duster front end conversion
Author Topic: 73 duster front end conversion  (Read 250 times)
crazycuda
« on: March 26, 2006, 02:38:01 AM »
This is probably a dumb question but will a 71 front end (fenders, hood, grill etc.) swap to a 73 with out to much problem?
70 Dustpan
Sacramento CA.
Re: 73 duster front end conversion
« Reply #1 on: March 26, 2006, 02:54:49 AM »
Yep, if you swap the whole frontend it's not that hard.
Hey, I'm a God again!
4406
« Reply #2 on: March 26, 2006, 09:08:03 AM »
I like the 71 front end way better, not so pointy if you know what I mean and sharks tooth Grill...... duster
Cudadust
« Reply #3 on: March 29, 2006, 05:27:48 AM »
The 73-76 A-bodies differ from the earlier models because of federal legislation regarding impact standards, the entire suspension sysetem and emission standards changed about 1973.  Many body parts will interchange between years but the change you are contemplating will probably be labor intensive and very costly.  Unless you have an abundance of time and money this project will not be a satisfactory endeavor.
Jamakin
makin678@hotmail.com Jamakin99
« Reply #4 on: March 29, 2006, 09:54:15 AM »
if your taking everything from the other front end it should be a bolt on.  The only difference on the fenders is a mounting tab (but wont matter if you do the entire swap) and a different marker light.  70-71 had the inlaid marker light and later had one that wasn't inlaid.
