Topic: A Body Drum Question (Read 499 times)
451 valiant
Ontario, Canada
Does anyone know if any company has made the A body 10x 1 3/4 brakes, but with the 4.5" bolt pattern for a bolt pattern conversion. I may just redrill but just thought I'd ask. Thanks
doug 371
i'm pretty sure ur on ur own...
440Ken
You need to redrill, or redrill the axle and install new studs. I had my axles done.
Former "God Member" with 1180 posts
qkcuda
Matt, did you buy new axles, or were you planning on redrilling yours? I ask because my axles and drums are redrilled and I am getting ready to take them out and replace them with Moser axles I bought. I just have to find a set of drums and backing plates from a big bolt pattern car first.
451 valiant
Ontario, Canada
Hey, I was planning on having them redrilled, they are for my dad's 69 swinger. He wanted to keep the a body rear drum and axle setup but have the BBP, will yours be for sale? I have an extra set of backing plates if you need them, they are the big ones (11" x 2.5").
67Dart34dr0
If he hasn't done the front yet, SSBC has a SBP disc conversion for 10" drum cars that should be a little cheaper than a front disc and rear BP swap.
qkcuda
Matt, as soon as I find all the brake stuff so I can install my axles, they will be for sale. The axles were filled and redrilled, with 1/2 inch screw in studs. The brake drums were in good shape and are redrilled. PM me, maybe we can work an exchange.
Dave
451 valiant
Ontario, Canada
I haven't installed the front yet, but already have all the parts to do it. Thank you for the info though!
67Dart34dr0
It crossed my mind a while back that it should be easy enough to get some decent core rotors and redrill them for SBP up front. Wouldn't you think so?
Kinda like the Scarebird conversion except using late A body disc setup.
qkcuda
I believe the center register (hub) is quite a bit bigger on the late model brakes.
440Ken
I believe the center register (hub) is quite a bit bigger on the late model brakes. Yes this is true. The axle studs are the only thing keeping the drum centered and that puts extra strain on those studs. Not an ideal situation for sure. ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif)
qkcuda
Matt, I tried to send you a message, but your PM box is full. Please go ahead with the brake parts. I can drive to you if it would be easier. Dave
