Topic: aligment question (adjustable strut rods) (Read 552 times)
Darren
Hey guys, I am getting an alignment on my 68 Dart this week, I have adjustable strut rods, Will the guy doing the work now how to adjust them or do I have to bring the Car in with them set to factory length? Thanks
B.B.D.of Corpus.
i would set them at factory length and only use them for fine tweaking the castor if needed. if you use the struts for setting caster it will put the lower control arm in a pretty good bind.
I just installed them as well, and I am going over to have the alignment checked later this week. It was set not long ago, so I am mainly going to make sure I haven't moved anything since I put them on. I'll tell you one thing, between the strut rods and the 90/10 shocks, the front end comes up right now when you hit the throttle.
JEDS67
Hey Guys Not to steel your thread but what brand of strut rods are you using.I saw some the other day with a pivot on one end is this the kind you are talking about.I can't seem to locate them again.I thought it was somebody who advertised here or one of the members.JEDS
Jeff, your PM box is full. I will try and post some pics of the strut rods in the next couple of days.
dartracer
Try this. http://www.reillymotorsports.com/store/home.php?cat=266
JEDS67
Thanks dartracer.I searched for them on his site but they didn't come up.Thanks again JEDS67
therocks
I have Bills on the 65.They are a nice piece.I think they were like $ 180.Id definetly buy them again.Rocky
Here are some pics of mine installed. Not the best, but it gives you some idea.
GLENNP
What is the measurement for the stock style with new rubber bushings? I took it apart without thinking about it.
480 old posts. Almost a God. If it doesn't make you go faster.......sell it to the the original resto geeks.
pauly v.100
i'm using firm feel pieces and i'm very happy with them. i consider them a must bec i'm also using poly lca bushings. when i went in for alignment i easily got 3.5 degrees pos. caster.
