December 04, 2008, 03:45:07 PM
| | |-+  A-body Strut Rod Questions????
Author Topic: A-body Strut Rod Questions????  (Read 391 times)
Cuda340
« on: March 30, 2006, 01:07:00 PM »
Are all A-body Strut Rods the same? I have a 1969 Cuda and one of my strut rods was bent. So I got another pair off of a 1971 Duster. They should be the same correct? There is a little difference between the two when I put them up next to each other. First the threads on the 71 are course and the 1969 are fine, no big deal... Second there are two stop flanges on the shaft one for the control arm side and the other for the k-frame bushing side. There was a 1/4" difference between this distance from the two different years. My main concern is that the 1971 strut rods may be a little short in that middle area I was describing or is that 1/4" not going to make a difference. Does this make sense?
I could make up the diffence by putting a washer in between the strut rod bushing and the retaining ring. But, I took off both sides of the 1971 car strut rods so I can change them both to be off of the same car. Plus I am in the process of rebuilding my front suspension completely. Basiclly am I looking for little to no preload on the LCA? I can play around with both sets. What do you suggest?
70 Dustpan
Sacramento CA.
Re: A-body Strut Rod Questions????
« Reply #1 on: March 30, 2006, 03:08:11 PM »
There is a difference in them because the newer ones use a different bushing. You can use them you just need to use then right bushings to go with them. I beleive that most rebuild kits come with the newer style bushing, but just make sure to ask them.
Hey, I'm a God again!
Cuda340
« Reply #2 on: March 30, 2006, 03:20:09 PM »
What is the difference between the two bushings- early one piece - later two piece?Huh
70 Dustpan
Sacramento CA.
« Reply #3 on: March 30, 2006, 03:59:58 PM »
The thickness of them. I think it's the newer ones are thicker.
jet-taz
« Reply #4 on: March 30, 2006, 08:25:38 PM »
get the one-piece ones from mopar p4529183.special material, i try the two-piece one's and found way to much of a loose fit.and they would'nt fit my hd strut rods from just suspension.
