September 06, 2008, 09:25:07 PM
| | |-+  Man , I see know that me & Vic is going to be OK.
Author Topic: Man , I see know that me & Vic is going to be OK.  (Read 1185 times)
bentwheel43
« on: March 30, 2006, 09:32:23 PM »
  I got my eddys today, they are 82cc  \/][ I think just cleaning them up will be good.  I see more in them, none of them ports  are the same but I gave it the Ray Charles test and they need a little work.  Iam thinking about milling them .050" just to start hammer
section 8 racing , we're nuts about racing"""'
dusterdarryl
Re: Man , I see know that me & Vic is going to be OK.
« Reply #1 on: March 31, 2006, 12:59:23 AM »
they've gotta be a goood thing aye Max ?
pwmax
« Reply #2 on: March 31, 2006, 10:58:00 AM »
How did you cc them? Those are bare castings, which comes with the guides unsized, and the seats not cut. edelbrock also throat cuts, and blends that after cutting the seat. But, yah, they do need work, and will respond well to mild work
Frank
Advanced performance
www.get-ap.com
bentwheel43
« Reply #3 on: March 31, 2006, 02:00:24 PM »
Frank
www.get-ap.com
  82cc was on the box,   Roll Eyes  so what about the guides they are not 11/32 ?      I was doing some 452s and bought some 3/8 x2.14 valves and 3/8 x1.81 dill the guides I can use those valves. \/][ I though that I had to buy 11/32 stiem valve.  The reason I bought the heads bare iam putting a  roller cam so I need better springs,so I have to do what it takes, Shocked   so can I mite put the 3/8 stiem valves?   will I have to drill them to put the 11/32 in it.    I didn't buy the valves yet.   thank you for looking at what I have.        I have a motor thats is  new in  my car but these heads are for next year.
68 HEMI GTS
« Reply #4 on: March 31, 2006, 02:21:25 PM »
11/32 is smaller than 3/8!!!
bentwheel43
« Reply #5 on: March 31, 2006, 03:05:10 PM »
yes before I bought these heads I was going to build some 452s,I bought some 3/8 stim valves 214/181, but then I bought these eddys bare I though that I had to buy 11/32 valves,but if I have to fit them I mite can use the 3/8 valves. I didn't know that they needed to be fitted.         can valve glides be drilled or will I have to get 11/32 valves and just fit them in?    I have the 3/8 valves now if I could use them without buying new 3/8 valves glides.     thank for helping me get strate.   BENT 43       Grin    OK   I cleaned the ex ports on 1 head ,all the sharp and missmatch edges are smooth,cast lines,the valves glide bosses where they pressed them in had a sharp flaired edge. I didn't take any out that I didn't have to. I didn't port them just clean.    after  and before
bentwheel43
« Reply #6 on: April 01, 2006, 11:15:24 AM »
 OK  I think I have it. I have to buy new valves I didn't understand what was going on but tom1951 had to resize the glides in the center. All that is ok because I have a lot of time on this motor, Iam not porting these heads yet but I will mill them .050 this time,after we get all the clean up done ,and the valves in I will cc the heads.    \/][ hoping for 74 to 72cc.      I think maybe .006" to .003"in the hole with .039" headgasket.      BENT 43
