July 09, 2008, 09:50:35 AM
| | |-+  Rubber brake lines 73-76
Author Topic: Rubber brake lines 73-76  (Read 486 times)
4406
« on: April 01, 2006, 08:54:05 AM »
Sorry about asking but I just completed my LBP Brake swap useing F body spindals and calipers and need to know if I use the stock 73-76 A body rubber caliper hoses or the F body style?
The F body ones have a bracket partway up from the line at the fram that I have no mounting hole for that I know of On my 68 and I have not looked at the stock A Body Lines. duster
bbscamp
Ehm.....B5 Blue am I?
Re: Rubber brake lines 73-76
« Reply #1 on: April 01, 2006, 10:59:22 AM »
I had a 72 Scamp that I converted to LBP disks.  The calipers were mounted to the rear of the spindles.  I used the 73+ hoses.  No problems. I also just finished a 75 dart with disk brakes.  the calipers were to the front of the spindles.  Same hose, no problem.  The routing is just different.    both set up are fine.     bbscamp
« Reply #2 on: April 01, 2006, 02:37:12 PM »
Thanks, They worked great!! bbd sign
