December 04, 2008, 03:58:44 PM
| | |-+  Vesidual Valves For My Disc/Disc Brake Set-up????
Author Topic: Vesidual Valves For My Disc/Disc Brake Set-up????  (Read 486 times)
70 Dustpan
Sacramento CA.
« on: April 01, 2006, 08:59:59 PM »
I'm getting ready to set-up the brakes system for my Valiant. It is a disc/disc set-up with the aluminum master cyl. in the stock location. It sits alot higher then the calipers so I don't know if I should run residual valves in the line for the front and back or not. I will have an adjustable prob valve for the back. Any input would be great.
Thanks Brent
Hey, I'm a God again!
GON_RACIN
Happiness is a warm gun.
Re: Vesidual Valves For My Disc/Disc Brake Set-up????
« Reply #1 on: April 01, 2006, 11:01:50 PM »
if i'm not mistaken, a residual valve isnt needed unless the M/C is mounted lower than the calipers
« Reply #2 on: April 02, 2006, 07:51:14 AM »
I can help here!!!
No need for the valve if you master is in stock location.
Link to one of my Beaters!!!
http://www.poppeckperformance.com/barracuda_1965.htm bbd sign
lake worth, florida
55robert@comcast.net
« Reply #3 on: April 02, 2006, 12:18:04 PM »
 agree
70 Dustpan
Sacramento CA.
« Reply #4 on: April 05, 2006, 12:32:37 AM »
Ok I don't need them, but should I run them?  I have read that it is a good idea to have them anyway. I don't want to spend the money and do the work of running them if there will be no difference with or with out them, but if they will make a difference. Just trying to get some good info.
thanks for the feedback so far guys.
Brent
GON_RACIN
« Reply #5 on: April 05, 2006, 08:39:53 PM »
FredDart
« Reply #6 on: April 05, 2006, 08:54:19 PM »
I guess the brakes might drag a bit.... the residual valve just keeps the brake fluid from getting back to the m/c if its located below the calipers.
Fred
70 Dustpan
Sacramento CA.
« Reply #7 on: April 06, 2006, 05:54:58 AM »
Good reading, Thanks. There's a lot more to it then I knew about.
Brent
