Topic: 10X1 3/4 REAR DRUMS!! WHERE TO GET THEM? (Read 1325 times)
4406
iVE POSTED FOR A SET OF REARS TO REPLACE THE ONES ON MY 68 bARRACUDA, i WOULD USE THE BACKING PLATES AND THE 10 X 1 3/4 IF i COULD FIND DRUMS FOR THE SET UP i HAVE. ANY SUGGESTIONS ON WHO CARRIES THEM?  ??
Last time I checked they were no longer available new. I picked up a decent set at a swap meet.
That figures, I wounder how hard it would be to do a swap useing my stock axels?
zman49445
are you looking for 5 on 4 or 4.5 on 5
Girfriends may come and go but I still have my 68 dart gt!!
frankwest
I have a good set from my Scamp 10 x 1.75 small bolt pattern , a little surface rust but no pitting and they are well under the 10.09 max size.
frankwest-at-adelphia.net
Tom1951
You can get new drums at www.rockauto.com, they will be 5 on 4" sbp. You can have a machine shop redrill them for 5 on 4.5" bbp
"73 Dart Sport, 11.5 to 1, 446, Racer Brown STX20, Eddy's, M1 single plane, 850 Mighty Demon, TTI's and soon to be installed a AlterKation... τΏτ
4406
I should have mentioned the axels are 4.5 bolt pattern. So now that I think about it I have to change the whole set up anyways.
As I posted above it looks as though its a waist of money redrilling axels unless you like redrilling brake drums also.
440Demon
I bought Moser axles, Had them do big bolt pattern, and just redrilled the drums.
demon340v
the 10X 1/34 that is the larger drum, then the stock A body right?
if you have teh lrg bp axels, all i have to say is you can buy brand new drumbs @ csk aka checker shucks kragen, if not you can hit up a b Body car for that drum as well
The 10 X 1 3/4" is ths stock small bolt A body 8 3/4" size.
demon340v
You should be able to get those at any part store
4406
actually Im being told that the 10x1 3/4 are not available new and the B body drums will not work because the SBP a body axel has a differant offset than the LBP axels. sometning like 1/4" so the drums will rub on the backing plate, so I would have to redrill the drums and Im not interested in haveing an extra set of holes in my brake drums.
Tom1951
4406, A-body 10 X 1 3/4 drums are available new. They are small bolt pattern so you will need to drill them for big bolt pattern. These don't have that big flange on them but they are for A-body axle offset. Go to www.rockauto.com The Pn is BD60123 from Wagner. Tom
