October 11, 2008, 09:25:22 AM
| | |-+  10X1 3/4 REAR DRUMS!! WHERE TO GET THEM?
Author Topic: 10X1 3/4 REAR DRUMS!! WHERE TO GET THEM?  (Read 1359 times)
4406
« on: April 02, 2006, 12:51:26 PM »
iVE POSTED FOR A SET OF REARS TO REPLACE THE ONES ON MY 68 bARRACUDA, i WOULD USE THE BACKING PLATES AND THE 10 X 1 3/4 IF i COULD FIND DRUMS FOR THE SET UP i HAVE. ANY SUGGESTIONS ON WHO CARRIES THEM?Huh?? thank you
Caledonia, ON Canada
Re: 10X1 3/4 REAR DRUMS!! WHERE TO GET THEM?
« Reply #1 on: April 02, 2006, 01:55:38 PM »
Last time I checked they were no longer available new.  I picked up a decent set at a swap meet.
« Reply #2 on: April 02, 2006, 02:20:05 PM »
That figures, I wounder how hard it would be to do a swap useing my stock axels?
zman49445
« Reply #3 on: April 02, 2006, 04:41:27 PM »
are you looking for 5 on 4 or 4.5 on 5 Huh
Girfriends may come and go but I still have my 68 dart gt!!
frankwest
« Reply #4 on: April 02, 2006, 06:21:53 PM »
I have a good set from my Scamp 10 x 1.75 small bolt pattern , a little surface rust but no pitting and they are well under the 10.09 max size.
frankwest-at-adelphia.net
Tom1951
« Reply #5 on: April 02, 2006, 07:14:28 PM »
You can get new drums at www.rockauto.com, they will be 5 on 4" sbp. You can have a machine shop redrill them for 5 on 4.5" bbp
4406
« Reply #6 on: April 02, 2006, 09:10:51 PM »
I should have mentioned the axels are 4.5 bolt pattern. So now that I think about it I have to change the whole set up anyways.
« Reply #7 on: April 03, 2006, 07:32:27 PM »
As I posted above it looks as though its a waist of money redrilling axels unless you like redrilling brake drums also.
440Demon
Streetsboro Ohio
« Reply #8 on: April 04, 2006, 12:55:28 AM »
I bought Moser axles,
Had them do big bolt pattern, and just redrilled the drums.
demon340v
« Reply #9 on: April 04, 2006, 06:33:47 PM »
the 10X 1/34 that is the larger drum, then the stock A body right?
if you have teh lrg bp axels, all i have to say is you can buy brand new drumbs @ csk aka checker shucks kragen, if not you can hit up a b Body car for that drum as well
Sacramento CA.
« Reply #10 on: April 04, 2006, 06:45:29 PM »
The 10 X 1 3/4" is ths stock small bolt A body 8 3/4" size.
demon340v
« Reply #11 on: April 04, 2006, 06:46:18 PM »
You should be able to get those at any part store
4406
« Reply #12 on: April 04, 2006, 07:03:47 PM »
actually Im being told that the 10x1 3/4 are not available new and the B body drums will not work because the SBP a body axel has a differant offset than the LBP axels. sometning like 1/4" so the drums will rub on the backing plate, so I would have to redrill the drums and Im not interested in haveing an extra set of holes in my brake drums.
Tom1951
« Reply #13 on: April 04, 2006, 11:58:32 PM »
4406, A-body 10 X 1 3/4 drums are available new. They are small bolt pattern so you will need to drill them for big bolt pattern. These don't have that big flange on them but they are for A-body axle offset. Go to www.rockauto.com  The Pn is BD60123 from Wagner. Tom
