Topic: 11/16" Tie Rod ends (Read 804 times)
demon340v
I had a question, these larger tie rod ends, will they bolt up to my steering linkage, i can't think of the part name but it's the sterring bar that hooks both sides of the wheels together.
70 Dustpan
Yep, the stud size is the same so the will bolt up to your center link / drag link. It's just the threaded size that is larger.
Hey, I'm a God again!
demon340v
center link! thanks  ok just needed to double check on that, i'm hunting all the parts down and so far so good! the tie rod ends and adj sleeves are alla day out from me
70 Dustpan
Measure the length of the C body sleeves. I got a set off of a early 70's C body and the are to long. (8 5/8" I think) I ended up have a set made up out of alum. hex stock at 7 1/4" long.
demon340v
Steve Strope over @ Pure Vison makesthem as well teh Hex stock, i di dnto factor in the length.
Thanks!
