December 04, 2008, 04:10:36 PM
| | |-+  11/16" Tie Rod ends
Author Topic: 11/16" Tie Rod ends  (Read 845 times)
demon340v
11/16" Tie Rod ends
« on: April 04, 2006, 06:31:47 PM »
I had a question, these larger tie rod ends, will they bolt up to my steering  linkage, i can't think of the part name but it's the sterring bar that hooks both sides of the wheels together.
Sacramento CA.
Re: 11/16" Tie Rod ends
« Reply #1 on: April 04, 2006, 06:43:45 PM »
Yep, the stud size is the same so the will bolt up to your center link / drag link. It's just the threaded size that is larger.
demon340v
« Reply #2 on: April 04, 2006, 06:47:13 PM »
center link! thanks lol ok just needed to double check on that, i'm hunting all the parts down and so far so good! the tie rod ends and adj sleeves are alla day out from me
Sacramento CA.
« Reply #3 on: April 04, 2006, 06:50:51 PM »
Measure the length of the C body sleeves. I got a set off of a early 70's C body and the are to long. (8  5/8" I think) I ended up have a set made up out of alum. hex stock at 7 1/4" long.
demon340v
« Reply #4 on: April 06, 2006, 04:15:46 PM »
Steve Strope over @ Pure Vison makesthem as well teh Hex stock, i di dnto factor in the length.
Thanks!
