October 11, 2008, 12:03:40 PM
| | |-+  Another master cylinder question
Author Topic: Another master cylinder question  (Read 308 times)
wedgie
« on: April 15, 2006, 08:43:42 AM »
I have converted my front drums to Wildwood discs and changed to a MoPar Performance master 2 bolt master cylinder. The brakes work well, but require a lot of leg pressure. Can anybody tell me which aluminum master cylinders have the smallest bore so I can decrease the leg cramps?
AA-slingshot
yeah...it's got a HEMI
Re: Another master cylinder question
« Reply #1 on: April 15, 2006, 01:41:17 PM »
have you checked pedal ratio??...for manual brakes you want around 6-1...power about4-1 ratio.
dmn71
Coal Valley, Illinois
« Reply #2 on: April 15, 2006, 10:29:56 PM »
Could you explain the pedal ratio. Steve
wedgie
« Reply #3 on: April 16, 2006, 05:46:24 PM »
The brake pedal has both a power and a manual hole for the pushrod. I am using the upper hole for the most leverage. Maybe I am being too critical, but I think that the brakes should be better. I wouldn't want to get into a panic situation with them.
