Topic: Another master cylinder question (Read 318 times)
wedgie
I have converted my front drums to Wildwood discs and changed to a MoPar Performance master 2 bolt master cylinder. The brakes work well, but require a lot of leg pressure. Can anybody tell me which aluminum master cylinders have the smallest bore so I can decrease the leg cramps?
AA-slingshot
have you checked pedal ratio??...for manual brakes you want around 6-1...power about4-1 ratio.
dmn71
Coal Valley, Illinois
Could you explain the pedal ratio. Steve
wedgie
The brake pedal has both a power and a manual hole for the pushrod. I am using the upper hole for the most leverage. Maybe I am being too critical, but I think that the brakes should be better. I wouldn't want to get into a panic situation with them.
