December 02, 2008, 06:13:28 AM
| | |-+  OEM xhd leaf springs or SS springs?
Author Topic: OEM xhd leaf springs or SS springs?  (Read 450 times)
FredDart
« on: April 16, 2006, 10:54:56 AM »
Should I go with the OEM leaf springs or SS springs on a street driven small block? I figure that at 100$ a piece, I should go new instead of re-arching my 225 springs and adding a leaf....
For traction I have a pinion snubber, should I keep my stock shackles?
Thanks
Fred
jet-taz
Re: OEM xhd leaf springs or SS springs?
« Reply #1 on: April 16, 2006, 11:26:15 AM »
go with the hd units
GON_RACIN
Happiness is a warm gun.
« Reply #2 on: April 16, 2006, 05:19:32 PM »
BEWARE that the mancini brand XHD leaf springs for A bodies are biased, and will you make your car sit crooked.
« Reply #3 on: April 16, 2006, 09:08:38 PM »
SS springs are stiff and may even require some creative installation techniques just to get them in. XHD is just that; Extra[i][/i][u][/u] heavy duty. Not semi HD, not used to be HD, but X-HD. It's all about spring rates. As I recall, the SS 002 & 003 springs are 160# P/inch. STD springs are generally around 100# p/inch, depending on model, as in it takes 100# to compress the spring 1 inch. SS's can and will make the rear of the car ride like a buckboard. Not really the choice for cruising, unless your boble-head doll in the back window likes getting headaches and whiplash.
  A bias to one side (R) is generally better to help control the engine's torque and evenly plant both tires. On launch the car wants to put more weight on the rear right as the engine torques over to the right taking the front left with it. With the heavier bias, the weight transfer is more distributed to the left as well. Increasing traction and control.
Birdius Rapidus
« Reply #4 on: April 18, 2006, 07:33:31 PM »
I installed the XHD on my RR street car. It rides like an empty dump truck. On the bright side I don't have any wheel hop.
Tom
sperrydan
I live for Mopar and my Ruth
« Reply #5 on: April 22, 2006, 01:04:45 PM »
wich one has a higher lift off the ride hight. I nee to get my wheels out of my wheel well more to get better tire clearance and i am building a 80% drag 20% street car
GON_RACIN
« Reply #6 on: April 22, 2006, 01:46:40 PM »
the biased XHD's will make the car sit around 1 inch or so higher on one side, and closer to 2 inches on the other
demon340v
« Reply #7 on: April 22, 2006, 03:51:59 PM »
i run SS springs on my Daily Driver Demon, i love them!!! although i do have traction problems now but that's due to a much higehr gear ratio then my stock 3.23 i sued to have
WRTMOPAR70
« Reply #8 on: April 30, 2006, 03:38:42 AM »
do the ss springs sit higher than the xhd ones
what is recommended for s street strip four speed car
383 4 SPEED DANA 60
