October 11, 2008, 04:24:37 AM
| | |-+  spindle to ball joint bolts
Author Topic: spindle to ball joint bolts  (Read 609 times)
440turner
« on: April 16, 2006, 03:00:01 PM »
I do not have any of the factory bolts, can I just go and get grade 8 bolts and put the head of the bolt on the rotor side? Also where can I buy strut rod washers?
nasty68
Eastern Shore of Maryland
kjh4435@aol.com
Re: spindle to ball joint bolts
« Reply #1 on: April 16, 2006, 05:23:52 PM »
If you are talking about the bolts that bolt the lower ball joint on, then yes.  They are 5/8" x 18 x 2.5" long (fine thread)  I just went and bought some grade 8 bolts in that side.  I had to grind the head of the bolts just a little because the inside of the rotor was slightly draging on them when i spun the rotor.  Not sure about the strut rod washers.
68 dart, 383, 727
97 wrangler sport, 4.0
« Reply #2 on: April 16, 2006, 06:57:35 PM »
The strut rod washers might be available from the resotration suppliers, otherwise I think you'll only find them used.
ucdcrush
« Reply #3 on: December 03, 2006, 08:00:22 PM »
Is the thread count important as long as they're fine thread? I was at the local hardware store today trying to buy some, they only had 20 threadcount or something. Now that I look at the parts more closely, it doesn't seem to screw into anything other than the nut behind the lower ball joint.
The tech pages say to use a squish type lock nut, is that the kind with a nylon insert?
dartman366
« Reply #4 on: December 03, 2006, 08:58:28 PM »
no, the squish type is swedged on on side of the nut to make the threaded hole out of round making it tight on the bolt, but I feel the nylock nut(the ones with the nylon insert ) will work just fine as long as you are not looking for origionallity. santa4
ucdcrush
« Reply #5 on: December 03, 2006, 09:06:40 PM »
thank you kindly. i'll go with the fine thread and nylock..
 santa2
« Reply #6 on: December 03, 2006, 09:39:09 PM »
I used grade 8 bolts with nylok nuts. Had no problem. Use loctite too.
