Topic: Line Loc (Read 468 times)
74DDS
Line Loc
« on: April 18, 2006, 06:22:55 PM » |
HeyIi just purchased a line loc and was about to install it, I was wondering if you guys had any tips or tricks on installing them, or running the wires and such, so any tips are welcome. Thanks.
GTS225
Well, if you want to disguise the fact you've got one in the car, you could run a fused hot lead to one side of the loc, then run the "ground" wire through a double pole, single throw toggle switch, along with the horn grounding wire. Using the switch, you could then switch from horn to line loc, and use the horn button to activate the loc. (Stealth mode.  ) Roger
green67cuda
I mounted my button inside the ashtray, by the lighter socket. that way, it stays hidden and is still in easy reach at the track.
silverbullet
I put a switch on the dash to activate the switch on the shifter knob, that way its easy to get to, but u can still disarm it.
74DDS
What wire do you use for your power source, does it really matter as long as it's hot when the ignition is on? thanks for the ideas, i'm not going to hide it, i was just wondering where you'd mount the selonoid in the engine bay area.
green67cuda
here's mine
vitamindart
ran mine on the firewall to the right of the master and ran a relay so that it turns on my brake light when its on ,so i don't pull a bOb just kidding i just wanted to know when it was on just in case the kidds flipped the switch on me
74DDS
what wire do you use as a power source, Just some random hot wire? Thanks for the idea of the arming switich, it's a good idea.
vitamindart
i just used a switched power feed so it only had power w/key on
green67cuda
I used the factory radio power connector. Mine has no radio, though.
sickt7cuda
505 - 400 block EZ-1's, 4.56 gear, 8" PTC 4500 stall best of 1.402 60', 10.338 @ 128.73
74DDS
what do you guys use as a power source?
green67cuda
