December 02, 2008, 06:48:54 AM
| | |-+  Power to Manual Steering
Author Topic: Power to Manual Steering  (Read 421 times)
74swangur
« on: April 19, 2006, 10:43:19 AM »
 Has anyone come up with a less expensive solution for the $100.00 coupler when going from power to manual steering? Also what's inside of here? (see arrow below)
Mopar Masters Creed: "We the all knowing, have done so much, with so little, for so long,...we are now qualified, to do anything, with nothing"
abodyjoe
South Jersey...
abodyjoe
Re: Power to Manual Steering
« Reply #1 on: April 19, 2006, 12:05:10 PM »
  had a frien take two of those stock cluples and weld them together to get his length...   i would just prefer to spend the money on the flaming river piece that bill sells..
1967dart406
CHARLESTON, SC
« Reply #2 on: April 19, 2006, 12:16:05 PM »
theres some shoes inside of that thing that ride on a shaft
pretty basic but can be a pain in the but
got to agree that unit bill sells is sweet an elimanates that big old coupler
74swangur
« Reply #3 on: April 19, 2006, 12:29:38 PM »
Thanks fella's.
 thank you agree
dodgee
« Reply #4 on: April 19, 2006, 03:03:05 PM »
  agree  flaming river is the way to go ,excellent product and easy to install.we are not allowed to weld steering components as such over here.
green67cuda
« Reply #5 on: April 19, 2006, 06:33:44 PM »
I made my own with 3/4" bar stock and 3/4" pipe:
(still kinda ugly because I never painted it.)
Ignore the white circle.  that was for someone else
74swangur
« Reply #6 on: April 19, 2006, 07:00:30 PM »
Looks like you added some length to the stock coupler. Is that a set screw in the piece you added or a roll pin. Did you have power steering brfore? I read somewhere that the input shaft for power and manual sectors are different sizes. If this is true did you use a stock coupler for a manual sector? Sorry for all the questions, the pic is a little dark and its hard to tell.
DartKnight
« Reply #7 on: April 20, 2006, 06:48:46 AM »
Here's something in the Moparts tech section I was going to try....
http://www.moparts.com/Tech/Archive/steering/13.html
Jason
green67cuda
« Reply #8 on: April 20, 2006, 09:20:36 AM »
it is kinda unclear.  I cut the round stock the same as the length difference between the power and manual.  I drilled the hole for the pin that holds the shoes the same distance from the end of the shaft as the hole on the stock shaft.  then welded the pipe to it with the shoes bottomed in the coupling and the end of the pipe touching the coupling seal.  Then drilled the hole in the open end of the pipe to be able to put in the roll pin to attach to the stock shaft.  (the last hole is the same distance from where the extension piece ends inside the pipe as the hole is from the end of the shaft so the end of the stock shaft butts up to the new extension on the inside since I cut the extension to the length difference between the power and manual.)
I don't remmebr what the length difference is, though.
I have a pic here somewhere I drew with Paint.  i'll see if I can find it and send it to you.  it clarifies this tremendously.
oh....and I think that picture above was the first one that ended up being right on the seal because the pipe was too long.  now it has some clearance from the pipe to the seal, with the shoes centered in the coupler.
74swangur
« Reply #9 on: April 20, 2006, 10:10:16 AM »
Thanks for the info green67cuda, I believe I can make this happen.
74swangur
« Reply #10 on: April 20, 2006, 10:12:17 AM »
Thanks for the help DartKnight. I believe I have seen this on a van in a nearby boneyard.
440Dreamin
66 dart GT 440 (EXPECTANT)
« Reply #11 on: April 20, 2006, 02:27:31 PM »
thanks for the reminder! I have forgotten more of these tips than i can remember \/][
I Love bbd sign
Fallen God member - just a schmuck now...
Coon Rapids, MN
jleilich
« Reply #12 on: April 21, 2006, 08:56:26 AM »
I would spend the cash and buy the flaming river unit.. I have it in my cuda,  It looks great, neat and clean.
Lars
ATX
« Reply #13 on: April 22, 2006, 01:25:56 PM »
The FR piece takes some slop out of the sterring also.
