December 02, 2008, 09:26:20 AM
| | |-+  Will and E body manual box fit an A body?
Author Topic: Will and E body manual box fit an A body?  (Read 383 times)
Lars
ATX
« on: April 21, 2006, 10:49:33 PM »
I found a decent deal on a manual box out of a 71 Challenger. I know the pitman won't work, but if I get the right arm, can I use it in my 73 Dart?
Thanks
mopartranman
Re: Will and E body manual box fit an A body?
« Reply #1 on: April 21, 2006, 11:46:20 PM »
yep  Grin
Lars
ATX
« Reply #2 on: April 22, 2006, 01:18:36 PM »
Would I be able to use my PS pitman arm on the manual box, or are the manual boxes unique to themselves?
RoachRunner
pr_jjc
« Reply #3 on: April 23, 2006, 12:06:00 AM »
PS pitman arm worked on my B-body when I did the manual swap, I'm assuming (and hoping!) that it will be the same when I do the same swap on my Swinger Smiley
D'oh! Stupid brain....
Lars
ATX
« Reply #4 on: April 23, 2006, 03:29:00 AM »
Well, I check the part numbers, the manual steering part# is different from the power steering part#. I ended up passing on the box because it would get tight in the center of the lock to lock.
nasty68
Eastern Shore of Maryland
kjh4435@aol.com
« Reply #5 on: April 23, 2006, 12:18:49 PM »
If i remember right, i took the manual box off of my 71 challenger and bolted it on the 68 dart and used the pitman arm that was on the dart. (power steering, /6)
68 dart, 383, 727
97 wrangler sport, 4.0
