Topic: Question on Bills upper A arms?? (Read 263 times)
ou812
Went to align the front end of the duster, and I cant get enough camber. How far out can I safely run the heim joints? Front is all the way in, and rear is 4 turns from all the way in. Castor was great at 6+ but couldnt get camber to zero. One side was 1.9 and other was 1.0 camber negative. I need to know just how much I can safely push the top arm out with the heim joints. Other than that, what a huge difference with the arms and struts!! Brian
Bill_Reilly
You can have an easy 1/2" of threads out past the jam nut with no worries. Normally, 2 threads out on each end seems to be enough on most cars, but alot can change that.
ou812
Thanks Bill, your the best!! Why do you think my duster needs to be setup different? Cant say enough about your products Bill, very very nice work! Brian
Bill_Reilly
Over the years, the frame rails can twist inwards from use/abuse - I don't hear about it very often, but it's often enough that I'm not surprised. Thats why I won't make the cheaper arms with welded on bushing ends - the odds are too high that a certain length won't work.
ou812
Abuse?? Hey Bill...thanks for all the help. I will let you know how well everything works after Pomona May 7th. Brian
