March 11, 2010, 09:43:28 PM
| | |-+  Turbo?
Author Topic: Turbo?  (Read 2546 times)
EFIDart
Re: Turbo?
« Reply #30 on: March 20, 2008, 01:18:59 PM »
Im here.. Im not quite at 1400 yet.. it was 1300 rwhp at 11 lbs pump gas but im sure at 12 it would be 1400. Turbos are nice 1 lb boost equaled over 100rwhp, and my engine should take 15 lbs quite easy on pump swill.
The big reason to go a single over a twin turbo is simplicity and cost!
With twins you need
2- Wastegates
2- Blow of vavles
2- turbos
With a nice single you can get away with 1 of everything (depending on displacement, I have to install a 2nd WG to bring it down to 5 lbs). The cold side plumbing is more on a twin and on a single there is more on the hot side.
If you size your turbo's correctly they can be equally responsive either single or twins. Also cam profiles are a witch doctors forumla! Smiley
You can stock block a turbo engine but don't expect it to live over 1000hp for too long. I went to a KB street 440 block for the simple fact its the best block out there and they can fix it if you ever window it. I run nothing wow for heads (victor 440s), walbros and a megasquirt for my EFI.
jyrki is definately right about starting to look at other things in the car once you make the power!
Ive had to get rid of my cal tracs and small tires because really 1.57 60 foots really suck. Also petaling the car all the way down the track is fun but doesn't result in anything more then a 9.1 or so Smiley.
So a backhalf is going in unfortunately because the tracks here suck.. and now a hammock will take place of the back seat! damn it! And the 727 handled the power except it never hooked so that tranny is doomed. It handled 1000 HP hooked but I dont think much more then that. Hence now i'm looking at a powerglide... which is kind of going to suck on the street now with only 2 speeds. The 8 3/4 all back braced, etc etc etc would possibly hold the power but a 9" now is in its place. Also need 25.5 now for the cage.. etc etc etc! So yes the list of things to do piles up.
Junkyard turbos are nice, but if your really cheap you can buy master power turbos so why would you screw around with used stuff? Ive learned you spend the money twice buying used shit, unless you know where it came from.
Another thing, pump gas E85 in the states is the ticket... if you class that as pump gas! I should be able to turn mine up to 25 lbs boost on that stuff.
Anywho if your thinking of singles stock block follow TT440's lead hes got something going that for sure.
joshking440
Re: Turbo?
« Reply #31 on: March 20, 2008, 05:50:24 PM »
Guys, we have been doing TONS of research on the turbo stuff and made the leap.  I am a full distributor for Precision Turbos... which are massaged garretts,  pricing and support is GREAT, and the horsepower even better,  we are building a motor with a single 106 that will be making around 1200 hp at the tires on E85.  We are also putting together a 8 second small block chebby and a small block mustang to run in the same time zone.  We build all of the headers in house on the cars as well as intercoolers and the plumbing, and if you run E85 who needs intercoolers.  Example  gt4276 which is $1618 from Precision, and about $1499 everywhere else is $1350 from us and we can install it, you need headers anyways, might as well turn them around an mount hair dryers on the ends.  Two of those gt4276 turbos is good to about 2100hp so thats plenty for most street applications I would say.  Pm if you would like more info...
jwmotors
Re: Turbo?
« Reply #32 on: March 21, 2008, 06:07:34 AM »
For what its worth , I found a recycler that buys aluminum and he gets turbos in pretty often . We bought 4 from him for 10.00 a piece . They were garretts and 1 cummings st50 . My oldest son who is 16 is building a turbo set-up on a firebird chassis at the shop and those fit his budget . About all he has to finish is a hat to blow through the carb .
Pages: 1 [2]  All Go Up Print
