November 22, 2008, 11:47:48 AM
| |-+  Early A-bodies
| | |-+  66 dart need help 331 hemi
Author Topic: 66 dart need help 331 hemi  (Read 1337 times)
thinking
« on: May 05, 2006, 10:20:06 PM »
i have a good 331 hemi and 66 dart has anyone ever put hemi in a dart or can it be done if so what needs to be changed thanks
sr71mopar
Santa Rosa, CA.
Re: 66 dart need help 331 hemi
« Reply #1 on: May 05, 2006, 10:25:23 PM »
There are a couple members here putting early hemi's in early A's.
I think it would be cool.
340fyd
« Reply #2 on: May 06, 2006, 08:58:46 AM »
 agree
Lee
Lee
64ragtop
« Reply #3 on: May 10, 2006, 04:57:05 PM »
"Wanderer" at Gentry's Garage was doing that some while ago.  He's more often found on the Early Valiant/Barracuda list these days, I think.
65s
« Reply #4 on: May 13, 2006, 03:11:28 PM »
This website here is good for this topic  -> http://hometown.aol.com/erlihemi/HemiBoak.html
Josh
« Reply #5 on: June 10, 2006, 10:19:11 PM »
You probably already know this but some 331's have part of the bell housing cast on the block. That makes them very difficult to adapt to a modern transmission. So make sure you have the later 331 that uses a more conventional bell housing setup.
fstfish66
« Reply #6 on: July 03, 2006, 01:00:42 AM »
there is a guy  in  ohio,,adapting  GM, bell housing,,for a 4 sped set up to the early 331 with bell attached,,
also some street rodders are now  milling off the cast bell and using an adapter plate to  mount a 727  or 904 A..
1966 barracuda blown 340 4 speed tubbed 33x22
1940 dodge street rod hemi with A/C
2002 cummins ram dailey driver
