Topic: Ignition (Read 190 times)
lodaddy
Ignition
« on: May 06, 2006, 09:03:34 PM » |
1974 Dart swinger. Car would start if while cranking you backed off the turn of the key just a little quickly but as soon as you let the key go it would die. I replaced the key unit, the switch, the ignition box, and the coil and the car wil not start unless I run a wire from the + post on the battery to the + post on the coil. What is wrong
Dartsport
Ballast resistor is bad!! Replace with a new one. Try joining the wires from each side of the ballst resistor together. It should start, and keep running.
 505 cu. in. , Alston chassis, CRT trans, FBO Ignition, 9.451et, 141.91mph, 1.278 - 60 foot, SO FAR!!
lodaddy
Hey thanks for the reply. I pulled the connector plugs back a little and wrapped a wire around all the post and it started as you stated. I put on a new ballast and the same thing happens it wont start
lodaddy
Got it going
