July 24, 2008, 06:49:57 AM
| | |-+  shock mounts for coil overs
Author Topic: shock mounts for coil overs  (Read 1028 times)
mopartony
« on: January 04, 2006, 12:14:02 PM »
does anyone make a shock mount that is longer than 2-2.5"?  I need to get more shock travel on my car and in order to do that I need to raise the rearend 2".  This ruins the look of the car.  So in short I am looking for shock mounts that are 4-5" instead of the 2-2.5" one.  any leads?
thank you
in advance
Ed
Phoenix, Az
Re: shock mounts for coil overs
« Reply #1 on: January 04, 2006, 09:37:15 PM »
Mancini sells the spring plates with more shock drop, but don't know how much of a drop.  If that doesn't work, you'll have to make your own.  I'd watch you don't go so low that the mounting point is lower then the wheel, if you get a flat tire they might drag.
Here's there online shop:  http://store.yahoo.com/chucker54/
formerly VIN_VL29U
mopartony
« Reply #2 on: January 05, 2006, 08:40:05 AM »
Ed,
Thanks they are local so I will check them out.
Tony
