Topic: shock mounts for coil overs (Read 1060 times)
mopartony
does anyone make a shock mount that is longer than 2-2.5"? I need to get more shock travel on my car and in order to do that I need to raise the rearend 2". This ruins the look of the car. So in short I am looking for shock mounts that are 4-5" instead of the 2-2.5" one. any leads?  in advance
Ed
Mancini sells the spring plates with more shock drop, but don't know how much of a drop. If that doesn't work, you'll have to make your own. I'd watch you don't go so low that the mounting point is lower then the wheel, if you get a flat tire they might drag. Here's there online shop: http://store.yahoo.com/chucker54/
formerly VIN_VL29U
mopartony
Ed,
Thanks they are local so I will check them out.
Tony
