November 22, 2008, 12:07:44 PM
| | |-+  Shumacher /6 to b/rb motor
Author Topic: Shumacher /6 to b/rb motor  (Read 347 times)
Sharpdart
« on: May 09, 2006, 01:13:23 PM »
Well we have are mockup block, heads manifolds, and tranny all lined up and ready to be put in.  I bought the Shumacher /6 kit about 4 years ago and dug it out on the weekend.
Not quite a bolt in deal this kit.  It seems nothing matches, and you have to grind and re-drill and grind to make it fit.
Has anyone else put the Shumacher kit in?
Any tips and hints would be appreciated.
guzzimike
1968 Dart GT (383)
Re: Shumacher /6 to b/rb motor
« Reply #1 on: May 09, 2006, 01:31:32 PM »
I used the Schumacher SB(273) to BB(383) full kit (Motor mounts, Tri-Ys, torque strap). It all went in pretty easy.
The only cutting needed was on the K member (per instructions) for the oil pump clearance and a bit of drilling for the Torque Strap. Then we leveled the motor with the shims provided and all's been good.
Are you sure you got the correct kit for your application..?
70 Dustpan
Sacramento CA.
« Reply #2 on: May 09, 2006, 01:51:44 PM »
What year is yours? Is it biscuit or spool mounts?
Hey, I'm a God again!
Sharpdart
« Reply #3 on: May 09, 2006, 01:51:51 PM »
Oh yeah.  Box says /6 to b/rb.  That is what we have.  Turns out for the /6 everything needs to be 'lowered'
"The driver's side on a 73' and up is 2 3/8" taller than a v8 k member"  So on the drivers side we have to drill one 9/16" hole through the motor mount, then cut off of the excess, etc, etc.
It will be worth it though.  Now I am really thinking about that limiter, seeing as the new drilled hole is real close to the outside of the motor mount.  Like a 1/4" close...
Sharpdart
70 Dustpan
Sacramento CA.
« Reply #4 on: May 09, 2006, 01:57:07 PM »
On the 73 up it's not that bad to do. Also you don't need a limiting strap because the mount on the driver side can't move after it's bolted up.
smitty72
I'll finish it someday
« Reply #5 on: May 09, 2006, 11:21:07 PM »
I used the 67-72 kit on my dart worked out fine. just followed the intructions and had to do a small cut for oil pump clearance but it went in fine
sr71mopar
Santa Rosa, CA.
« Reply #6 on: May 10, 2006, 12:34:49 AM »
My shoemaker kit is in a 68 /6 k-member(bisquit). The trans mount was within an 1/8", and I can move the motor side to side or up and down at least an inch.
The mounts were $150. If I had a spool k-member, I would talk to Jim.
