December 02, 2008, 08:29:05 PM
| | |-+  Plastic Lens Refinishing
Author Topic: Plastic Lens Refinishing  (Read 414 times)
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« on: May 14, 2006, 12:24:41 PM »
Any ideas what to use on plastic lenses ie: Tail light, turn signal etc. to restore them? Mine are kind of hazy and grubby looking, I've heard of using metal polish? AutoSol etc....Any thoughts?
Ryan
Dr. Hunter S. Thompson
Darren
Re: Plastic Lens Refinishing
« Reply #1 on: May 14, 2006, 12:27:15 PM »
Spray them with a good clear coat and they will look like new.  Darren
norwaycharger
« Reply #2 on: May 14, 2006, 01:13:38 PM »
Yepp that will work, but i always use a tranparent plastic primer first.
You can also mix some color in the clear,ex black, red, orange.
Be carefull with the color not more than 1% to max 3%, i use as litte color as possible then 3-5 coats
AKA, the drummerboy
http://www.pink-division.com
DartKnight
« Reply #3 on: May 14, 2006, 07:42:01 PM »
We sell the plastic refinishing kits for headlights at work (the ones that take the haze out of the lenses on Fords, Dodge Neons, etc.). It worked great on my co-worker's Mustang; made the headlights look brand-new. I want to try it on my tail lights, but I'm going to find a back-up set first (just in case).
Jason
cu440da
Saint Paul, MN
« Reply #4 on: May 15, 2006, 12:20:21 AM »
I used Meguir's plastic polish to clean up my rallye dash lenses. They were so cloudy I could barely see the intsruments. Lots of elbow grease and polish later, they look darn near new. Should work on colored lenses, too.
'67 Notchback- 12.85 @ 109mph
Duster Five-O
Port St. Lucie FL
« Reply #5 on: May 16, 2006, 08:35:56 PM »
We use this on lightbars. http://www.plexusplasticcleaner.com/plexus.html The Meguires plastic polish works pretty good to.
Turtle Wax polishing compound works good to.If it's really bad you can wet sand w/ some 2000 grit then use the polish.
A God on the previous board.
1967dart406
CHARLESTON, SC
« Reply #6 on: May 17, 2006, 10:18:48 AM »
i use meguirs palstic polish with a polishing wheel
i wet sand the lens with 1500 or 2000 grit first
Ryan (Strange246)
Merrimack NH
« Reply #7 on: May 17, 2006, 10:20:47 AM »
Thanks guys, I'll post results when I do them...
Ryan
sweatybetty
« Reply #8 on: May 19, 2006, 06:14:14 PM »
the plexus is GREAT stuff. i have a jeep with the vinyl windows. they get scratched alot. clean the with the plexus and most of the scratches are gone. got the stuff at carquest for about $ 9
demon340v
« Reply #9 on: May 19, 2006, 07:51:29 PM »
i picked up some of that mcguirs stuff, going to try it out this weekend
