October 07, 2008, 11:43:04 AM
| | |-+  Manual vs Pwr box input shaft
Author Topic: Manual vs Pwr box input shaft  (Read 287 times)
bbscamp
Ehm.....B5 Blue am I?
« on: May 14, 2006, 10:23:49 PM »
I'm going to install a manual box (small sector) onto the 64 Valiant (power steering).  I'm happy about the Pitman arm just swapping over!  However, putting the 2 boxes side by side, I see that the input shaft on the manual box is smaller than the power one.  That means that the column shaft is now too short AND is has the wrong coupler.
does the firmfeel  adapter take into consideration the change in inputs shaft diameter?   are all manual smaller than power on the input side too?   what adapter can I use?
Bill_Reilly
Administrator
White Haven, PA
Re: Manual vs Pwr box input shaft
« Reply #1 on: May 15, 2006, 01:16:00 AM »
https://www.reillymotorsports.com/store/product.php?productid=16141&cat=254&page=1
On a budget, someone also mentioned the stock coupler from a dodge van with manual steering will adapt you over....
Power boxes are all 5/8" X 36spline and manuals are all 3/4" X 36spline.
