December 02, 2008, 08:15:20 PM
| | |-+  sheet metal NHRA rule
Author Topic: sheet metal NHRA rule  (Read 314 times)
mopowers
« on: May 16, 2006, 05:10:19 PM »
With a fuel cell in the trunk, does NHRA rules state that sheet metal must separate the trunk space (ie. package tray and rear seat)?  What gauge metal does it need to be?  Does it need to be completely welded?
2006 Dakota
nasty68
Eastern Shore of Maryland
kjh4435@aol.com
Re: sheet metal NHRA rule
« Reply #1 on: May 16, 2006, 09:51:53 PM »
Yes, you must seperate the drivers compartment from the trunk with either .024 steel or .032 aluminum.  It doesn't have to be welded just sealed.  I will pop rivit mine to the frameing and the package tray and use some type of sealer around the edges.  Tech inspectors at my track just look to make sure their isn't daylight coming thru around the sheet metal.
68 dart, 383, 727
97 wrangler sport, 4.0
mopowers
« Reply #2 on: May 17, 2006, 01:10:30 AM »
can you lay carpet over it?  do they make you pull the carpet to show them the joints?
2006 Dakota
signet
« Reply #3 on: May 17, 2006, 02:01:48 AM »
i did mine with steel.
the package tray and behind the rear seat and they passed it, the battery was relocated to the trunk and they make you do the same mods.
but once i had my complete interior removed i noticed that fumes liquid ect could also move into the drivers area through the c pillar or sail panels and through the rear window regulator area were the wheel house is on a 2 door.
so i cheated and used foam in this area but it should be bulkheaded off with metal of the right thickness,it's you who needs the extra time not the inspectors.
and you might get a picky inspector and he'll zap ya.
mopar stu
« Reply #4 on: May 17, 2006, 02:26:26 AM »
just curious mopowers,why is your tire on a jack?and the jackstand under the bumper?
mopowers
« Reply #5 on: May 17, 2006, 10:05:50 AM »
we pulled the rear suspension/rear end last weekend.  The jack stands are on the rear frame rail.  We just jacked a slick we had layin around up into the well just to see what it is going to look like.  Almost looks like we're jackin it up by the tire huh?
2006 Dakota
mopar stu
« Reply #6 on: May 17, 2006, 11:17:24 AM »
i knew you had a good reason,i just had to ask Shocked
