December 02, 2008, 08:54:25 PM
| | |-+  upper ball joint removal (help please)
Author Topic: upper ball joint removal (help please)  (Read 527 times)
6ix5ive
« on: May 19, 2006, 09:04:01 AM »
Hello everybody
I have two questions which will probably can be categorized in the "bone head category".
1)  I am trying to remove the control arm upper ball joints on my 1965 Barracuda with the larger ball joint socket (1973 and up A body (ø = 1.915")) and I can not get them to budge.  Does anybody know any tricks to getting these off.  I have been using a large breaker bar and have soaked the joints in oil.  Is there anything else I can do?
2) My car is a 1965 barracuda with a disc brake upgrade.  I need to rebuild the front end but I need to verify the year of my front end.  As I mentioned above the Upper control arm is from a 1973 and up A body.  Since the upper control arm is from a 1973 and up A body is it safe to assume I can order a 1973 and up rebuild kit for the front end?  Or are some of the front end parts interchangeable with 1966-1972 A body front end parts?
Thank you for any help and have a good day
70dart408
Re: upper ball joint removal (help please)
« Reply #1 on: May 19, 2006, 11:41:55 AM »
                      Leaving the upper control arm attached to the car I used some stuff call
                      PB Blaster and let it sit over night. Next day went out using the special
                      socket with a half inch breaker bar and a cheater bar on the end and both
                      of mine came right out. (70 Dart Swinger)     Good luck with yours!!!
« Reply #2 on: May 19, 2006, 11:53:04 AM »
You need to use an impact OR a LONG breaker bar (4-5 feet). You need the rebuild kit for the 73, EXCEPT the pitman and idler arms. They need to be for the 65.
sweatybetty
« Reply #3 on: May 19, 2006, 06:20:26 PM »
i use a small torch with a fat flame to heat stuff but not too hot then spray some penetrating oil. the heat expands the part a bit allowing the oil in the gap. you may want to get some other opinions on heating control arms though.  anyone else?
Lars
ATX
« Reply #4 on: May 19, 2006, 06:34:12 PM »
Use an impact, that'll get them out. That's what I had to do to my 73.
A13Dart
Minnesota
« Reply #5 on: May 19, 2006, 08:23:45 PM »
My socket is 3/4 drive and I use a breaker bar and long pipe like Jim says. Had to use a map gas torch on one project. When using the cheater it is nice if someone can hold the socket flush on the ball joint.
mike.
dmn71
Coal Valley, Illinois
« Reply #6 on: May 19, 2006, 11:11:30 PM »
Same as 70dart408, worked for me on the 71 demon.  Steve
Halfaed
To move rapidly
« Reply #7 on: May 24, 2006, 12:41:01 AM »
Use heat and then candle wax in it!  Grin
Doesn't stink so bad.
rank
« Reply #8 on: May 29, 2006, 11:23:49 AM »
Are you sure somebody hasn't welded the ball joint to the UCA?
krabysniper
« Reply #9 on: May 29, 2006, 01:05:32 PM »
Only a TOTAL MORON would weld the balljoint to the control arm, and I do mean TOTAL hammer
mopartranman
« Reply #10 on: May 30, 2006, 01:06:48 AM »
Impact shoud do it. Or use a long breaker bar for leverage.  Well... I must be a total moron.  Grin Grin Cause i tack weld them in when i replace them on drag cars. Seen several pop out race cars that carry the front wheels alot.
GregZ
« Reply #11 on: May 31, 2006, 12:58:23 AM »
  agree I've tack welded a few myself.
