December 02, 2008, 08:41:14 PM
| | |-+  final blocking.. body lines
Author Topic: final blocking.. body lines  (Read 353 times)
mopfried
« on: May 19, 2006, 07:10:13 PM »
I am down to the final blocking stage of my Scamp project. Its nice and straight all over, I just want to make sure all the body lines are nice and straight too. Any sugesstions?
Re: final blocking.. body lines
« Reply #1 on: May 19, 2006, 07:42:52 PM »
A long STRAIGHT flexible board (plastic or ?). You will see waves with it that you won't see without. I don't have one, but Jeff is nearly done with the body work on my 67 Barracuda. I'll have to see if I think I need one. I'd really like to get paint on this weekend.
mopar stu
« Reply #2 on: May 19, 2006, 08:02:42 PM »
put tape on the top edge of the line and sand,then put tape on the bottom edge and sand some more,this will keep you from sanding down the body lines.also,a light spray of dark primer will show the imperfections better,just focus on the lighter areas after sanding it down.
71 demon child
« Reply #3 on: May 19, 2006, 08:42:45 PM »
my preference is a long straight board.I prefer non flexible.If your not an experienced body man you can get yourself in trouble with a flexible board.It can cause waves.Either way just take your time.
taking donations
mopfried
« Reply #4 on: May 19, 2006, 09:08:10 PM »
I have already long boarded the sides. I have a way of seeing even what the board wont show with a guide coat. I use Omni or PPG cleaner. Wipe it on good and wet. Stand off at an angle and its like it has a good coat of clear on it. Glossy as can be! Look at the reflection and you can see even the slightest wave. That is not my issue. The lines...... I want the lines to be straight. I can see they arent perfect. They aren bad.... but I want a way to make them as near perfect as I can. I am using straight line tape above the line with a guide coat, sand,  then lay down tape below it, pull the top piece and guide coat and sand. I am just wondering if there is a better way.
mopar stu
« Reply #5 on: May 19, 2006, 09:49:31 PM »
sure would like to see some before and after pics.  we like the visual thing.
dartracer
Strasburg CO.
« Reply #6 on: May 19, 2006, 11:51:56 PM »
Run your tape the full length of the body line on top. 2 full wet coats of primer let dry and sand with a long block. Then repeat on the bottom line. That should make your line strait. Thats how I did my car.  Dave
rjsjea
ProTouring Demon
« Reply #7 on: May 20, 2006, 06:40:52 AM »
you are on the right track......tape above/below, sand up to the tape.....it's a time consuming process
71 demon child
« Reply #8 on: May 20, 2006, 11:11:55 AM »
 agree.sounds like your doing good.You seem to have your own method and it's working for you.I wouldn't switch up now.There is many methods.What your doing sounds good.Can't wait to see it!
taking donations
