October 07, 2008, 10:01:25 AM
| |-+  Early A-bodies
| | |-+  Hooker semi fenderwell header install on early a's
Author Topic: Hooker semi fenderwell header install on early a's  (Read 5696 times)
DJVCuda
« on: January 05, 2006, 02:47:34 PM »
The template they give you shows DOUBLE the size that was cut - since the motor was out it didnt need it - the hole is mainly for installation purposes
The tire clearence is pretty good, ALOT better then full fenderwells, the coardboard is for new sheetmetal template, to cover  the holes from the template that hooker sends you ( keep in mind that the holes are 1/2 the size they recommend cutting!!?!??!)
the #2 tube will have to be unbolted, pulled out of the slip connector and laid down on the frame to be able to remove the oil filter.
the collectors are 2 1/2 " and the passengers side drops lower to accept the lopsided crossmember.
they gotta flo better then my splitfies, BUT they are a lot more work.
6469mopar
JACKSON, NJ
Re: Hooker semi fenderwell header install on early a's
« Reply #1 on: January 05, 2006, 02:57:07 PM »
I HAVE THE SAME SET UP IN MY 64   BUT I HAVE A LITTLE  TIRE RUBBING ON THE PASSINGER SIDE  HEADER TUBE
sycboi
Huron, Ohio
« Reply #2 on: January 06, 2006, 08:27:39 PM »
Upgrade those brakes    Cheesy
SuperBeast
'70 Dart
Roller 383 w/ much aluminum
« Reply #3 on: January 06, 2006, 09:13:59 PM »
damn car isn't fast enough to need better brakes...  the guy built up the 273.. i think he overcammed it..
DJVCuda
« Reply #4 on: January 06, 2006, 10:44:45 PM »
I think that car ran in the HIGH 16's at the track this summer - it was a customers car at my buddys shop... single master cylinder and all...  <):
« Reply #5 on: January 07, 2006, 01:22:43 PM »
Lot of work.
sunsetdart
us4ever365@hotmail.com
« Reply #6 on: March 31, 2007, 01:46:14 PM »
I'd go to a remote oil filter. It will get really old , really fast, having to undo the headers to change the filter.
pishta
« Reply #7 on: May 28, 2007, 10:27:18 AM »
Do your ports line up with the head? I had a set of those on my '65 A/340 combo and the ports we almost 1/4 inch off. They drilled the flange too low and all the exhaust footprints on the gasket were almost touching the bottom. Course, didnt find out until I took em off one day to replace the gasket. Sent the gasket to Hooker header group of Mr Gasket and they said it was a manufacturing error, "do you have your receipt?" I said "No, they are 3 years old..what does it matter, its not a wearing part, it was how it as made" no dice.... Frustrated
sunsetdart
« Reply #8 on: July 10, 2007, 07:27:22 AM »
I had these custom made for my 66 Dart.motor is a 360, and headers go under chassis.
dusterdarryl
« Reply #9 on: September 09, 2007, 06:40:11 AM »
but just imagine how it will breath.....  but does leave room for more cubes later
dartman472
« Reply #10 on: November 28, 2007, 05:32:55 PM »
I AHD THOSE ON MY DART YEARS AGO, THEY LEAK BAD,THERE ARE A PAIN IN THE BUTT TO CHANGE GASKETS,AND THE OIL FILTER HAS TO BE RELOCATED...ANOTHER REASON I WENT BIG BLOCK!!
