December 02, 2008, 10:07:49 PM
| | |-+  Help with rear suspension
Author Topic: Help with rear suspension  (Read 989 times)
rrayotte
« on: May 30, 2006, 04:37:25 PM »
I have a Dodge Dart '68.  I put new rear leaf spings in and moved them in 3 inches.  When I set the car down (full weight) the rear shackles hit the frame (swing back).  Any suggestions as to what my problem might be?  Thanks!!!!!!!!!!!!!
green67cuda
Re: Help with rear suspension
« Reply #1 on: May 30, 2006, 05:00:04 PM »
tops of shackles mounted too far forward.
dangerdawg
« Reply #2 on: May 30, 2006, 06:18:05 PM »
springs too long?, same as schackles too far forward.
rrayotte
« Reply #3 on: May 30, 2006, 07:02:19 PM »
New heavy duty springs, less arch.
Halfaed
To move rapidly
« Reply #4 on: June 01, 2006, 04:46:18 PM »
Definately sounds like the top mount is too far forward.
dangerdawg
« Reply #5 on: June 01, 2006, 05:15:09 PM »
I do remember when I installed mt re-arched springs that my shackles went forward before the wheels were on the ground, I just pryed them back, I think that was because of longer shocks which let the axle droop more. keep us informed, okee doke?
dangerdawg
« Reply #6 on: June 01, 2006, 09:08:20 PM »
oooops too far back right?  hhhmmmm, let me think.
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« Reply #7 on: June 02, 2006, 02:01:41 AM »
Did you use the hole in the frame for the rear shackles? I had the same problem, if you drill out the existing hole in the frame like the instructions say, the factory length shackles are too short...
Dr. Hunter S. Thompson
mopowers
« Reply #8 on: June 02, 2006, 02:04:00 AM »
Are you not supossed to use stock shackles if you relocate the springs?  Thats the first time I've heard that.
2006 Dakota
Ryan (Strange246)
Merrimack NH
« Reply #9 on: June 02, 2006, 09:37:42 PM »
You can use the stock shackles if you put the hole through the frame rail low enough, but if you drill out the existing hole in the frame it's too high up and causes the springs to hit the frame...
Ryan
mopowers
« Reply #10 on: June 03, 2006, 02:31:26 AM »
Ryan
So what shackles do you need to buy to do it right?  What shackles come in the relcation kit from mopar?  I heard they were stock length.
2006 Dakota
Ryan (Strange246)
Merrimack NH
« Reply #11 on: June 04, 2006, 01:56:23 AM »
Ryan
You can buy aftermarket shackles that are longer, but the best way to do it to is to just drill the holes for the shackles to mount to lower in the frame rails...Here's mine, (trunk floor removed for clarity) See where the tube is to mount the shackle? it needs to be moved closer to the bottom of the frame rail for the shackles to work right...
sickhemi
« Reply #12 on: June 04, 2006, 04:20:39 AM »
that was nice of you to remove the trunk floor too show him the problem lol
mopowers
« Reply #13 on: June 04, 2006, 12:07:44 PM »
Would an inch lower work with stock shackles Ryan?
2006 Dakota
Ryan (Strange246)
Merrimack NH
« Reply #14 on: June 06, 2006, 12:25:15 AM »
Doing what I can to help the common man LOL
Ryan (Strange246)
Merrimack NH
« Reply #15 on: June 06, 2006, 12:31:33 AM »
If I did it again I'd just put them in so that they were as low in the frame as possible, IE:bottom of the tube flush with the bottom of the frame rail...I got pissed with mine and ditched the shackles all together and went to sliders...Not on the road yet so I cant attest to that being a good or bad decision...
Ryan
