Topic: rearend location (Read 268 times)
moparn1
Full Monty Racing
OK I JUST INSTALLED THE MP OFFSET SPRING HANGERS AND I'M TRYING TO THE REAREND HOWEVER WHEN I PUT A LOAD ON THE REAREND IT THROWS IT OFF 5/8 OF AN INCH. I ALSO NOTICED THAT WITH THE REAREND CENTERED THE MEASUREMENT FROM BACKING PLATE TO LEAF SPRING IS DIFFERENT FROM SIDE TO SIDE. IS THIS NORMAL?  ANY HELP WOULD BE APPRECIATED.
bow chicka bow wow
A13Dart
Are the new spring pertches welded now?
mike
moparn1
Full Monty Racing
NO I HAVEN'T WELDED THEM YET.
bow chicka bow wow
A13Dart
You have the spring seats clamped in place with the u-bolts for test fitting.
The seats should be an equal distance from the axle tube flanges, same for the backing plates. Mine are 1/16 off, but that is factory quality control.
The MP seats have an oversized loacation hole in them, This might be why the housing is off to one side.
If everything is tight, can't see why the assy should move 5/8 when loaded.
mike
