July 06, 2008, 11:36:23 AM
| | |-+  Neutral saftey switch ???
Author Topic: Neutral saftey switch ???  (Read 518 times)
392dart
« on: May 31, 2006, 04:27:25 PM »
Does any one know where the neutral saftey switch is on four speed
mopowers
Re: Neutral saftey switch ???
« Reply #1 on: May 31, 2006, 04:30:59 PM »
I didn't think there was one.
2006 Dakota
« Reply #2 on: May 31, 2006, 06:48:19 PM »
There isn't one, however some later cars used a clutch interlock switch. There is no need for one and you do shorten the life of the thrust bearing face on the crank if you fire up with the pedal depressed as all of the weight of the pressure plate is on the thrust surface with no oil pressure.
Some cars also used a seat belt safety switch in that circuit.
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #3 on: June 01, 2006, 04:43:44 PM »
I actually have a nuetral safety switch on a later 4 speed clutch pedal set-up...........If you have one, it would be on the clutch pedal arm under the dash. To by-pass it the wire coming off of it goes to the voltage regulator, this is were a wiring diagram comes in handy, this wire must be grounded. This is what I did on mine. 4 speed
Shawn
69CLONE
dangerdawg
« Reply #4 on: June 01, 2006, 05:26:42 PM »
don't mean to steal the thread, hey shawn haven't seen ya around for awhile, get in touch with me ok?
