November 22, 2008, 06:05:19 PM
| | |-+  The cam is finally out of 67Dart383 engine. AKA 383Kidd
Author Topic: The cam is finally out of 67Dart383 engine. AKA 383Kidd  (Read 2775 times)
67Dart383
Nasty Dart from Memphis, Tennessee
« on: June 01, 2006, 07:38:22 PM »
Hey we pulled the cam a few minutes ago, we were disappointed of what we found.  The lifter that was stuck had a hole in the bottom of it , there were chippings off the side of it on the very edge.  THe lobe directly under it was goudged down.
Here are the #off the cam we cain,t find any matches to it anywhere right now.
CB8773
312h-8
CWC     EP45
67 Dart 383 MP590, Crane 1.6 R/R, headers, 906, 850 MIghty Demon, Performer RPM, 3inch exhausts, 727 R/M, 9.5 PTC 4500 flash stall w/ 2800 brake stall, 8 3/4 rear with P/T 4.30, on MT ET St Rad 11.77@112.97mph
Steve DeTar
Re: The cam is finally out of 67Dart383 engine. AKA 383Kidd
« Reply #1 on: June 01, 2006, 07:58:18 PM »
Thats bad luck.  You will need to pull the short block and inspect all the bearings.  Most likely all your bearings have metal embedded in them.  If you still have the oil filter cut it in half and look inside.  While you are there, pull the oil pickup and remove the metal from the screen and flush it out real good.  Also the metal is in all the oil galleys, so you will want to pull all the plugs and flush it out also.  Been here before, don't overlook this step.
gsmagnum
« Reply #2 on: June 01, 2006, 10:08:06 PM »
That sucks that you will be out your car that much longer.
It might not be a bad idea to keep your eyes open for a running big block.
Steve DeTar
« Reply #3 on: June 01, 2006, 10:34:08 PM »
When Michelle's little 383 cam went south, it too grinded a hole in the bottom of the lifter.  I hate that cheap soft stuff.  Anyway, the metal/iron was in everything.  Had to machine the crank, new main and rod bearings, new cam bearings, had to flush the block, had to flush the rocker shafts, had to buy a new oil pump. That metal even made its way into the valve springs!  All I can say is this....if you go thru it right it will last.  If you try to do something cheap, it won't.  The pick up tube looked clean till I pulled the screen off.  Don't forget to blow out the oil holes after the crank has been machined...it too may have iron filings in it also.
67Dart383
« Reply #4 on: June 01, 2006, 10:47:29 PM »
This is a nightmare this was the last thing on our mind.   What makes the lifter have a hole in the bottom of it and what makes the lobe wear away like that it only did it to just one lobe and lifter all the rest looked fine. We are saving up for an assembled 360 stroker that we are going to put in it in a year or 2.   For right now we are going to clean the inside as best as we can change the oil real good put 2 filter mags on the new oil filter.
Steve DeTar
« Reply #5 on: June 01, 2006, 11:24:26 PM »
Improper cam break in..like letting it idle on first starts..lack of assembly lube, lack of lifter rotation, excessive spring pressure, improper lifter preload on the lifter, too much lash, soft cams, soft lifters. They all will wipe a cam.  You must pull all the oil galley plugs to flush.  When you first came here to bbd sign and explained your car and engine, we all knew something was wrong. We were not trying to bust your chops!  We were telling you the truth even though you did'nt want to hear it.   I'm sorry for all the bad luck, we all are.  When someone else makes a sale on something, sometimes people have good intention not telling you everything, because it would'nt sell if they told you the truth.  Take it with a grain of salt.  Mopar Fever gets everybody one time or another...it is the knowledge we pay from our own pockets to know.  Good Luck and don't let it get you down.  Besides, you might score a 440 in the future and then we can go with you thru this process of getting it done without all this extra trouble.  Just because this jerk lied to you don't mean you need to sell your car either..just stay calm and things will work out..trust me...Steve DeTar
my64dart
« Reply #6 on: June 02, 2006, 12:13:34 AM »
Hey 383 Kidd,
      Sorry to hear about your bad luck with the camshaft. But you have to put it behind you now & get the motor fixed up the right way. Even if you have to put off racing until next year. It will give you & your dad something to look forward to . Just think about all the knowledge your get'n from this cam problem. Now you know how to disassemlble most of the motor & see the inside moving parts. Just be patient & do a good job. And don't try any shortcuts because a good mechanic will always do a job the right way. Besides that, you have a lot of friends here to help you out.
     Jim K
67Dart383
« Reply #7 on: June 02, 2006, 02:58:53 AM »
The guy who had the car before us may have been drinking to much when he put this engine togethere..   He had to of had some Adjustable Roller Rockers on there I looked up the cam and the specs say you cannot run that cam with stock rockers.
HEre is the specs:
Comp Cams Drag Race Cam needs 4500stall, needs 4.56 to 4.90gears
Power Band: 4000-6500
Lift both IN & EX: .540
ADV Duration both IN & EX: 312
Duration @ .050 both IN & EX: 260
These are the parts that are specified for this cam:
Lifters: 867-16 Pro-MAgnum (This we don't have they are some crappy Summit Lifters)
Timing CHain: 3104 Hi-Tech Roller Race Set (That we have)
Rocker Arms: 1321-16 Pro-MAgnum Roller Rocker Arms (We do not have at all)
Valve Springs: 925-16 (That we do have)
67Dart383
« Reply #8 on: June 02, 2006, 03:39:27 AM »
Hey I also found some Proform Roller Tip Alluminum Shaft Mount ROckers at Summit for 199.95 I have a 20 dollar coupon I can use. Has anybody used them or have you heard about them are they good.
dusterdarryl
« Reply #9 on: June 02, 2006, 04:35:55 PM »
you'd be better off buying a gasket set & a set of bearings that any rockers right now
Steve DeTar
« Reply #10 on: June 02, 2006, 11:30:01 PM »
They are cheap, buy something good so you don't have any problems in the future.  Some old crane or Iskey ducticle iron jobs are better than that.   I paid 545 for my Harland Sharps, but I had to modify them to the head.  If they go, no big deal to me.  And this is the same attitude you must acheive.  Think twice, buy once.
mrhotrod
Chicago,IL
mrhotrod1964@hotmail.com mrhotrod1964
« Reply #11 on: June 02, 2006, 11:42:38 PM »
if your going to replace all the bearings which you should, replace the rings also while your in there. Just to be on the safe side. And replace the oil pump itself. I went thru the same problem before. Cam could have not been heat treated from factory correctly the cam I had fail on me was also a comp cam. I will never buy one of theres again.
1972 Big Block Scamp 9.80 @ 138mph
2006 Cummins Turbo Diesel Ram 4x4 Dually
1966 Plymouth Valiant Big Block Project Car
dusterdarryl
« Reply #12 on: June 03, 2006, 05:17:58 AM »
gee iv had an exellent run from comp cams,
bentwheel43
« Reply #13 on: June 03, 2006, 11:28:27 AM »
HEre is the specs:
   kidd,when you called him to buy and he thought you was going to buy, he saved the money and took the parts off and put the stock parts back on because if you coat the inside the motor like yours you also know to put the right rockers,on a picture you have it has a deg. bushing ,at one time it was right and as for the convertor he took it out to and saved over $500 or more so he saved over $1000 with rockers,pushrods,and convertor.
67Dart383
« Reply #14 on: June 04, 2006, 03:38:20 PM »
I have some very good pictures of the cam and lifters it wil shock you.
lake worth, florida
55robert@comcast.net
« Reply #15 on: June 04, 2006, 04:07:31 PM »
shock us
bentwheel43
« Reply #16 on: June 04, 2006, 04:21:25 PM »
shock us
    Evil Hell, if it was not hurt that would  be skocking, but we know its  F  d up  lol bash turst me.
bentwheel43
« Reply #17 on: June 04, 2006, 04:33:22 PM »
  Undecided Whats your plan to fix it are you going to take it apart or put a cam and let it rip?       \/][ you should have it done by now Cry
67Dart383
« Reply #18 on: June 04, 2006, 07:50:47 PM »
We have our camshaft on order we are going to put it in this weekend. I am working on the pictures right now. We are going to clean it up as good as we can.    Here is our procedure we are going to change the oil put new oil and oil filter in it and a filter mag on the oil filter, then we are going t obreak the cam in for about an hour then we are going to change the oil and oil filter again then let her rip until she goes down south.
67Dart383
« Reply #19 on: June 04, 2006, 07:55:57 PM »
Pictures
67Dart383
« Reply #20 on: June 04, 2006, 08:00:56 PM »
More pictures
67Dart383
« Reply #21 on: June 04, 2006, 08:06:00 PM »
More pictures
ksdartguy
« Reply #22 on: June 04, 2006, 08:33:20 PM »
Are you replacing cam brgs?
If not, check all oil holes to make sure they are aligned. (the one in pic is off a little)
Also make sure cam will turn without too much drag.
What cam did you end up with? Smiley Smiley
Rick
67Dart383
« Reply #23 on: June 04, 2006, 08:43:49 PM »
How can we aligned the cam bearings oil holes up without taking them out.
We are getting an ultradyne cam its supposed to outperform the Lunati Vodoo cam.
« Reply #24 on: June 04, 2006, 09:56:11 PM »
You can't other than drilling the hole out fromt the oil galley up. That will introduce more filings to your oil system too. Talk to your local machine shops and see if they have a left over set of bearings (from when they screwed up installing a set and had to buy a full set).  It's a long shot but sometimes luck starts to go your way and you look like you're about due.
bentwheel43
« Reply #25 on: June 04, 2006, 10:17:06 PM »
 I think all the bearing in the motor is like those cam bearing,them cam bearing need to be lined up better, look and see if some mite be off worst.
67Dart383
« Reply #26 on: June 04, 2006, 10:27:33 PM »
I have a question if the cam has lobes smaller than the lifter face will the lifter be prone to going bad since the lifter face is not fully contacting the cam lobe.
when runnig a cam in a mopar should you get a cam that has lobes that are matched to .904 inch diameter of the lifter.
Do you think the cam I showed you was a problem as soon as It was put in.
Also wouldn't you lose power if the lobes of the cam were for chevy and fords lifters?
bentwheel43
« Reply #27 on: June 04, 2006, 10:43:24 PM »
 your lifters spin in the bore,them cams is not flat they have an angel on them that makes the lifters spin     Roll Eyes but roller cam are flat
67Dart383
« Reply #28 on: June 04, 2006, 10:46:34 PM »
SteveDeTar, you are  going to get mad when you see the specs.            The guy at Lunati cam said he can get the cam in a single bolt but it will be an ultradyne, because the lunati are three bolt.  We want to keep our timing chain there is nothing wrong with it.
Its a hydraulic.
Advertised Duration IN/EX: 276/284
Duration @ .050 IN/EX: 234/242
Gross Valve Lift IN/EX: .513"/.533"
LSA / ICL: 110/106
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 2200-6400
We are getting a 3000 stall.
Steve DeTar
« Reply #29 on: June 04, 2006, 10:51:13 PM »
That sounds good, it will have a rumpity rump sound to it.  I am also glad you are getting a 3,000 stall.  It will work with your cam.  I hope you are getting their matching springs, cause you know you can't use yours.  What heads are on your motor?  I forgot.
Pages: [1] 2  All Go Up Print
