July 06, 2008, 09:56:33 PM
| | |-+  Minitub question with picture
Author Topic: Minitub question with picture  (Read 3348 times)
mopowers
« on: June 03, 2006, 07:47:07 PM »
I just started minitubbing my 66.  The frame is a C-channel and when you grind the side of the frame to make the inner tub sit flush, it separates the frame from the floor pan.  Do I need to weld the floor back to the frame, or can I just weld the inner tub to the frame then weld the floor to the tub?  I'm sorry if this is a stupid question, this is my first experience minitubbing a mopar.  Thanks for the help.  I'll get a picture very soon.
2006 Dakota
mopowers
Re: Minitub question with picture
« Reply #1 on: June 03, 2006, 07:57:20 PM »
Here are a couple picture to help explain my question.
2006 Dakota
cochez
« Reply #2 on: June 03, 2006, 08:18:23 PM »
I think they all do that...I beleive the floor is just spot welded to the flanges....I tack welded mine at the seam and were the mini tub meets it...
rpmrich
i dont burn rubber, i make tires scream
« Reply #3 on: June 03, 2006, 09:56:41 PM »
i rewelded mine all the way. then just ground it back down smooth. it felt stronger,
lake worth, florida
55robert@bellsouth.net
« Reply #4 on: June 03, 2006, 10:16:35 PM »
i welded the tub to the frame then welded the floor to the tub.
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« Reply #5 on: June 04, 2006, 01:51:10 AM »
 agree thats how i did mine...
Dr. Hunter S. Thompson
Halfaed
To move rapidly
« Reply #6 on: June 04, 2006, 02:03:38 AM »
Same here! Then I smeared seam sealer on it all to hide the crappy job!!!! lol
Looking good!!! I guess we don't have to tell you how important it is to get everything cleaned up before you weld it!!!! Grin moon
Birdius Rapidus
« Reply #7 on: June 04, 2006, 10:12:56 AM »
 agree agree
Weld it to the frame and then up top to the trunk floor. It will be good and strong.
Tom
mopowers
« Reply #8 on: June 04, 2006, 12:14:19 PM »
Thanks guys, I thought it would be over kil to weld it solid before weld the tub in.  The frame thinner than I thought.  I tried welding it and burned through on the lowest setting on my Lincoln MIG..  Do you think I need thinner wire, maybe .025?
2006 Dakota
Birdius Rapidus
« Reply #9 on: June 04, 2006, 03:01:15 PM »
You will have problems welding the top side with .030. Use .023 and wash it side to side just a little bit to move your heat. .030 should be fine inside the wheel well tying the tub into the frame keeping most of your heat on the frame.
Tom
mopowers
« Reply #10 on: June 04, 2006, 03:57:18 PM »
Do I have to weld it solid or can I just weld 1" portions a few inches apart?  Then slap some polyurethane seam sealer over all the joints.
2006 Dakota
Birdius Rapidus
« Reply #11 on: June 04, 2006, 09:21:15 PM »
I'm sure that will be fine. But I prefer to weld all of it. I like to have the weld be 99% of the sealer. Stitch weld it to prevent warpage then go back and tie your stiches together.
Also, I was able to get the filler pieces installed in two pieces per side. I cut the strips long and then cut a few 2" x 4" 's. I placed the 2" x 4" 's between the floor of the shop and the bottom of the wheel well. I hammered the wood to get them as vertical as possible. This holds the filler strips tight to the bottom and helps correct the high / low situation of the two well halves. You can slide the filler strips around as needed and use a rubber mallet to form and tack the upper corners.
Tom
rpmrich
« Reply #12 on: June 04, 2006, 11:53:02 PM »
i sprayed the inside of the wheel well with undercoating untill it covered the welds
rpmrich
« Reply #13 on: June 04, 2006, 11:55:33 PM »
here's one of the inside
rharveysr
« Reply #14 on: June 06, 2006, 01:26:00 PM »
I am going to run out on a thin limb here....Cant the filler strips be tacked between the wheel well halves instead of welding them on the bottem or inside???
Or...what would be the another option so that the inside of the wheel well looks like it came from the factory ...nice and fat?Huh
Thanks
Rick
19swinger70
« Reply #15 on: June 06, 2006, 02:39:40 PM »
you could butt weld them in, but it's going to require more cutting/trimmiing/ fitting work. bending the contour to fit in between the halves might be pretty tedious, but if your good at sheet metal work, im sure you could do it.
Birdius Rapidus
« Reply #16 on: June 06, 2006, 07:54:20 PM »
That could be done by using the method I outlined above. After you jamb the filler in place,just put some scribe marks on the filler and cut it. That is alot of work that I didn't want to do.
Tom
mopowers
« Reply #17 on: June 06, 2006, 08:00:37 PM »
When you lap the filler pieces in, do they rust because they are bare metal.  Or does the polyurethane seam sealer seal the rust out?
2006 Dakota
dustertogo
« Reply #18 on: June 06, 2006, 09:47:19 PM »
 just spray them with weldthrough primer before welding them in and rust shouldn't be a problem.
Halfaed
To move rapidly
« Reply #19 on: June 07, 2006, 01:47:44 AM »
Then after you have it all done, spray it with epoxy primer and paint it! drinks
70_440_Swinger
Almost an A-Body
« Reply #20 on: June 13, 2006, 10:12:34 PM »
Tom
That's a real clean looking job Tom. Wish you had done my tubs...lol
Looks like Stevie Wonder welded mine...
79 Volare - 360, Auto
440 in the Works
mopowers
« Reply #21 on: June 13, 2006, 11:15:10 PM »
Hey Tom, I picked up some .023 wire and wow it makes such a difference.  I'm not even that good, but I notice it.  I'll throw up some pictures when I'm done.
2006 Dakota
Rate
If you got time to turn, you're going too slow.
« Reply #22 on: June 14, 2006, 12:57:09 AM »
Damn that's some clean welding >_> I can barely even go in a straight line Tongue
Birdius Rapidus
« Reply #23 on: June 14, 2006, 01:52:45 AM »
Stevie Wonder. lol I don't care who you are, now that's funny.
Just make sure the metal is absolutley clean. Just a little contmaination will ruin your job.  And of course, stay away from inner shield.
Thanks guys. I do use the .030 when welding structural items. I post some chrome moly tig welds when ever my wife lets me start that project.
Tom
70_440_Swinger
Almost an A-Body
« Reply #24 on: June 14, 2006, 09:58:56 AM »
Tom
By that do you mean Flux-core wire? Cause that's what I was using....
440 in the Works
Birdius Rapidus
« Reply #25 on: June 15, 2006, 12:15:56 AM »
Tom
You can use it, but the home use inner shield tends to spatter a little more and fills the parent metal with contaminants. It is mainly used on structural steel (iron workers) where shielding gas isn't practical; welding with air movement like a breeze and pushing alot of wire.
Tom
mopowers
« Reply #26 on: July 03, 2006, 06:32:15 PM »
I finished up my minitubs this last weekend.  I will post some pictures in a bit.  They aren't as nice looking as your Tom, but not too bad for my first try.
2006 Dakota
mopowers
« Reply #27 on: July 03, 2006, 06:36:35 PM »
2006 Dakota
70_440_Swinger
Almost an A-Body
« Reply #28 on: July 03, 2006, 06:39:41 PM »
Looks pretty good to me! Nice job!
440 in the Works
Birdius Rapidus
« Reply #29 on: July 04, 2006, 01:34:57 AM »
Yeah you did a great job. Keep it up.
Tom
Pages: [1] 2  All Go Up Print
