Welcome,
. Please
login
or
register
November 22, 2008, 05:27:56 PM
1 Hour
1 Day
1 Week
1 Month
Forever
The BigBlockDart Message Board
Technical
Chassis, Suspension
two bolt aluminum master cylinder
Pages:
1
Topic: two bolt aluminum master cylinder (Read 643 times)
caper
Cape Breton , Nova Scotia
on:
June 05, 2006, 10:29:32 PM »
Anybody have a part # for a two bolt aluminum Master cylinder for standard brakes on a 69 dart? What vechicle? Thanks.
lake worth, florida
Re: two bolt aluminum master cylinder
Reply #1 on:
June 06, 2006, 12:26:40 AM »
i made an adaptor out of 1/4" aluminum plate.
440Demon
Streetsboro Ohio
Reply #2 on:
June 06, 2006, 12:41:44 AM »
Summit Racing sells both.
The adapter and the mastercylinder.
Josh
Reply #3 on:
June 06, 2006, 07:24:21 AM »
I get a MC for an 85 fifth avenue at the parts store and make my own adaptor like is listed in the tech pages.
Cheap and easy.
mjudd
Springfield, Il.
Reply #4 on:
June 06, 2006, 07:51:16 AM »
Mancini has everything
http://chucker54.stores.yahoo.net/mascylad.html
green67cuda
Reply #5 on:
June 06, 2006, 09:23:15 AM »
I used a 1980 Volare manual disc MC from the parts store and made my own adapter.
268darts
Reply #6 on:
June 07, 2006, 10:56:43 PM »
I used the top 2 studs. I did have to open up the hole in the firewall a little bit so the master would bolt up flush.
Josh
Reply #7 on:
June 10, 2006, 10:10:31 PM »
Quote from: 268darts on June 07, 2006, 10:56:43 PM
You also would have had to cut 3/8 of an inch of the brake pedal push rod if you go this route.
vitamindart
Reply #8 on:
June 11, 2006, 11:28:17 PM »
bill sells both and a offset one if you need more clearance
mrhotrod
Online
Chicago,IL
Reply #9 on:
June 12, 2006, 12:26:35 AM »
I have the a brand new adjustable brake pushrod if you need one. PM me if interested.
1972 Big Block Scamp 9.80 @ 138mph
2006 Cummins Turbo Diesel Ram 4x4 Dually
1966 Plymouth Valiant Big Block Project Car
Pages:
1
Please select a destination:
General Category
=> Off-Topic
=> Wanted
Technical
=> Engine, Drivetrain
=> Chassis, Suspension
=> Body, Paint, Interior, Wiring
=> Early A-bodies
