November 22, 2008, 06:17:55 PM
| | |-+  charging problem
Author Topic: charging problem  (Read 411 times)
70dusterjohn
charging problem
« on: June 07, 2006, 04:47:56 AM »
Ok, what I have is on my street car, went to the new style charging system about two years ago! Now the car will not charge at all , with either system?Huh The car is a 67 dodge with a 440. Any help would be great! Anymore I go out to work on and end up just staring at all those f@#king wires, and don't know where to look next! Got the hole flippin dash pulled out of it, still can't find anything! About ready to put a forsale sign on it and shove it in the front yard!! Well anyhow any help would be great !!! Thanks hammer
STOMP AND STEER
mopar stu
Re: charging problem
« Reply #1 on: June 07, 2006, 11:34:58 AM »
i think it's time for a 0ne wire alternator.http://www.powermastermotorsports.com/mopar3.html
« Reply #2 on: June 07, 2006, 12:10:29 PM »
The charging system is fairly simple. You have a regulator, alternator, and battery. The alternator can be tested at any auto parts store. You can't just swap an early alt for a late one and have it work. It has to be wired for each one and use the appropiate regulator. You might also have a weak battery.
70dusterjohn
« Reply #3 on: June 08, 2006, 02:39:10 AM »
Yup the charging system is fairly simple, but I can't find the problem, I converted per mopar wiring t0 the new charging system and have done my 67 Barracuda, 68 Coronet R/T , 68 Coronet, and my 69 Dart, all are still working with no problems! The 67 Coronet on the other hand is a another storie, I even tried to switch back to the old system and still nothing, had both tested, and even got new one, nothing! Tried reg. new and old. got new ones to, still nothing, bypassed amt. gauge still nothing! New battery, tested twice still nothing!!! I'm lost, no where else to go!?HuhHuh? Maybe front yard!!!!!!!!!! hammer
STOMP AND STEER
Ed
Phoenix, Az
« Reply #4 on: June 08, 2006, 03:37:50 AM »
If it's a 2 field wire alternator, you can ground one terminal and put 12v on the other.  Should go to full charge, or make lots of smoke.   Like the other's said, you can get the alternator check at any parts store.  If it's good, next in line is the regulator, if it's not the wiring.
formerly VIN_VL29U
« Reply #5 on: June 08, 2006, 11:57:36 AM »
Make sure the engine and body are grounded together properly. Check the ground on the regulator, too.
demon340v
« Reply #6 on: June 08, 2006, 02:14:44 PM »
yeah my popz runz that on his Runner when he hooked it all up it was pretty cool to see the alt. guage peg out with ease and he does not have any further problems
Ciscodog
« Reply #7 on: June 09, 2006, 12:03:30 AM »
I don't care for Powermaster - I prefer East Coast  www.ecae.com
