November 22, 2008, 07:04:19 PM
| | |-+  K-Frame
Author Topic: K-Frame  (Read 800 times)
66gt500
K-Frame
« on: June 09, 2006, 07:37:42 PM »
i have a 73 duster and it has a slant six and i have a 360 for it and i was wondering if i have to change the  k-frame  in order to put the 360 in it or should it fit right in.some people say it should fit right in and other people say i have to change it. Huh
shorty thompson
Re: K-Frame
« Reply #1 on: June 09, 2006, 07:58:26 PM »
Yes you do . Unless you can do some really good fabricating .
66gt500
Re: K-Frame
« Reply #2 on: June 09, 2006, 08:13:06 PM »
i bought a 74 dart sport and it had a v8 in it. so i bought it for the engine and k frame, but that guy said it was a factory v8 car but when i looked up the vin number that was on the car, it was a factory slant six car. wierd huh. but it looked like the k frame that was under it was never changed. so i looked at both at them and they looked almost the same. so i dont know.
shorty thompson
Re: K-Frame
« Reply #3 on: June 09, 2006, 08:37:46 PM »
I think,,,,,,,you can buy offset motor mounts to put a V-8 in the slant - 6 car , but I don't know where . I just heard that you could .
a-bodymopars
Re: K-Frame
« Reply #4 on: June 09, 2006, 09:05:07 PM »
go to www.engine-swaps.com and it will tell what you need. schumacher creative services @ 206-364-7151 have the motor mounts u need , but they are $150.00 dollars and $20 for shipping and they come with all the hardware, this should help u out.
cuda74340
Re: K-Frame
« Reply #5 on: June 10, 2006, 01:25:27 AM »
if your making a drag car out of your duster you can get a set of solid frame mounts (aka) elephant ears. one of the draw backs is lots of vibrations in the car.
Re: K-Frame
« Reply #6 on: June 10, 2006, 01:52:08 AM »
I suspect you may already swap mounts if the k-members are the same.................
19swinger70
Re: K-Frame
« Reply #7 on: June 10, 2006, 11:11:42 AM »
im pretty sure you can use the /6 k member. just buy, or fabricate the required mounts. also, it's probably advisable to upgrade the torsion bars.
im using a 74 /6 k frame in my 67 cuda, but im using elephant ears.
rank
Re: K-Frame
« Reply #8 on: June 16, 2006, 09:33:34 AM »
>fabricate the required mounts.....
Any tips on how to get the engine in the right place (i.e. leveled and lined up properly)?
Bill_Reilly
Administrator
White Haven, PA
Re: K-Frame
« Reply #9 on: June 16, 2006, 10:56:13 AM »
If the V8 was in the 74, and the k frames are the same, then it'll bolt in to the 73. If they're different, then just use the slant frame and get the conversion mounts from schumacher. Even on the spool mount frames, the conversion mounts relegate the fab work to a little drilling and grinding, which is easy to do at home.
If you want to fab up your own, put the crank centerline 1.25" to the passenger side and 5.25" above the top floor of the k frame - this is the technically correct measurement at the front of the crank, but you can move it around a little for header clearance without any worries. You should definitely have your headers or manifolds on the engine when you locate it so you're sure everything fits when done.
rank
Re: K-Frame
« Reply #10 on: June 16, 2006, 02:17:29 PM »
Thanks Bill.
1.25" from the center of the frame rails?
Bill_Reilly
Administrator
White Haven, PA
Re: K-Frame
« Reply #11 on: June 16, 2006, 05:16:29 PM »
Yep. It's 30" across the middle, so set the crank at 16.25" from the drivers rail...
rank
Re: K-Frame
« Reply #12 on: June 19, 2006, 03:40:33 PM »
You rock.
thank you
